window adjustment
Old 04-17-2005 | 03:43 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
window adjustment
i am trying to adjust my windows i have the up and down correct, when i shut the door the window holds preasure on the door. when the door is rolled down half way, i can move the window in and out about 1- 2 inches. i tried adjusting what i can see but i'm not sure if i am doing it right.
Old 04-23-2005 | 10:33 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i had the same problem on mine and had to replace that whole window track thing in there. i think it's called an "f-channel" and runs about $65, unless you go to a yard, of course. anyways, it's the piece that the window glass itself is attached to, so before you or whoever does it, i would check around and make sure there is a replacement glass available. mine didn't break, but the potential is there.
KAM
Old 04-24-2005 | 09:51 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Thanks alot
Old 04-25-2005 | 01:13 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You need to adjust the rear track for the in/out tilt angle of the window. Right below where the rear up-stop is, there is a bracket that holds the track to the door. It looks a little like an "L" shaped bracket. It has two screws holding it to the door, and just inside the inner door panel from those are the in/out adjustment screws. Loosen the screws, and pull the track INWARDS (it's a lever sort of thing... seems like the bracket is adjusted too far outwards, causing the window to tilt in) until you get the proper alignment.
J-money
01-04-2019 10:45 AM
Fronzizzle
09-08-2015 01:10 PM
scottmoyer
09-07-2015 08:06 PM
SG91camaro
09-05-2015 11:27 PM
Quick Reply: window adjustment
