Difference between power/manual doors?
Old 04-15-2005 | 02:24 PM
StealthElephant's Avatar
Car: 87' Iroc
I noticed on hawks that they differentiate the manual doors from the power doors. Is this because the doors are different? I have power doors, if I go get a used door, will I be able to swap all the stuff from my old door into the new door if it was a manual or do I have to make sure it was a power door so the electrics will fit.
Old 04-15-2005 | 02:36 PM
BlackMagic's Avatar
Car: 1986 Firebird
Personally i have not been inside the doors of the firebird yet, but i have been in other doors of cars, and the brackets inside to hold the electronics for power doors were not in the manual doors. Maybe the birds are the same way, maybe not. Like i said i dont know first hand on the firebird doors yet.
Old 04-15-2005 | 07:38 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
The doors inside are exactly the same.
Old 04-15-2005 | 10:28 PM
Car: 87' Iroc
So any 82-92 camaro door will work? I'll be able to swap everything from my current power door?
Old 04-15-2005 | 10:43 PM
Derth Deboblo's Avatar
Car: '91 Firebird (blown apart)
Engine: *cough*BOAT ANCHOR*cough*
Transmission: Slushbox
Yes, any '82-'92 3rd gen door will fit. Yes you can swap the power components into a manual door and vise-versa.
-Derth
Old 04-15-2005 | 10:49 PM
Car: 87' Iroc
Aight thanks, why on earth does Hawks list the power and manual doors separately then?
Old 04-16-2005 | 12:21 AM
Genopsyde's Avatar
Car: 91 RS
Engine: 355
probably for the ppl that don't want to swap the internals.
Old 04-25-2005 | 01:32 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
will z-28 door panels with power windows work on my 6 cyl parts car doors with manual windows? i want to use the manual cranks. is it as easy as making a hole for the crank?
will the ground f/x swap onto it?
thanks for any info. my parts car has perfect doors and my z's doors are a dinged up mess.
Frozer!!!
01-19-2024 05:55 PM
1992 Trans Am
05-10-2023 08:19 PM
86IROC112
04-09-2016 11:20 PM
Out-Cast
08-23-2015 07:33 AM
BlackTopKing
08-19-2015 01:13 PM
Quick Reply: Difference between power/manual doors?
