I started sanding my front bumper cover...
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
With 80 grit, I began sanding in class. I discovered very quickly that there were SIX layers of paint on that nose. Six fracking layers of paint? Why the hell did someone put six layers? The top most layer was flaking off like nothing- and you could literally pull it off and the underlying paint was still shiny... Someone didn't scuff!!! No wonder it looked like crap.
But anyway, I'm down to bare plastic in the majority of the nose, and there are no cracks although I bumped a tree a few winters ago. You could see the spider cracking through all six layers of paint, down to the factory "primer" over top of the bumper (if you could even call it that). I'm going to hit it with 150 today and feather it out, get at least 3/4 of that paint outta there even on the undamaged areas. My teacher advised me to take it down to the bare plastic in the damaged area, however also mentioned that the paint looks fine in other areas that it won't hurt anything to leave it in non-stress areas.
I'll be painting the cover off the car, so a blend is not possible. I don't think my odds are really good at color matching, but in the unlikely even that I do, that just means I'm cool.
1 Post
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I want to do this too, but have no experiance and no teacher to guide me along. tell me how yours comes out. what paint are you using? are you even gunna try and match it? Dennis
Car: 1992 Firebird
Engine: forged 357
But anyway I'll be using PPG's K36 high fill primer, DBC basecoat with 2021 clear. Total cost of supplies including sandpaper, reducer, and plastic repair for the broken mounting tabs, will be about $200. This is including the two little side gfx that angle against the bumper and the fender. I get a student discount, however, so you might be looking at a little bit more money if you are doing a similar thing out of pocket.
It's very easy to do all of this. If your current paint is fine and not flaking off, you can get away with just scuffing the hell out of it with soem 150-220 grit, but if you need to take some paint off I was using a DA with 80 grit for my 4-6 layers. Inside the nose where the fog lights and turn signals go is a PITA to get to, so you're going to have to sand with a tiny piece of paper and your finger to catch all of the curves. Be incredibly careful with a DA on body lines, especially if you're going as low as 80 grit.
I can help you more when you need it
1 Post
Engine: 388 Carb
Axle/Gears: 4.10
Thanks I appriciate that. my car right now is in my automotvie class so when it gets home I will be working on that b/c the person before me had a bra on it and hit something so the paint is horrible in the front bumper.
Car: 85z28,
My camaro bumper had 8 on it. I send them out and get them blasted. It cost like 75/ 80 bucks. U can spend that very fast in sand paper. And My time is worth money so comes out alot cheaper than me sitting there with a DA. And u can match paint with out blending it. U have to know what u are doing but u can. There called test panals. Black car u don't have to blend. Pearls and candys. U have to blend. But for your basic colors u can get away with matching.For your tabs on the bumper u should plastic weld the first than use the glue.That way u don't have to sit there for 15 20 mins trying to hold that tab in place.
Car: 1992 Firebird
Engine: forged 357
Car: 1992 Firebird
Engine: forged 357
tuesday I primed my bumper with K36 (with DCX814 flex) and wednesday I wetsanded it with 400 then 600. Took over 3 hours and I half-assed it. I'm going to finish it up later today (technically since its so late) and then seal, paint, and clear it. Hopefully I can bake it and buff it.
Car: 1992 Firebird
Engine: forged 357
Well no go on the painting today, some jerks stole my paint booth
But I mixed up my color and finished wetsanding the bumper
Car: 1992 Firebird
Engine: forged 357
Well I painted it today. I am satisfied with the results however I ran the clear in a few areas. That damn thing is so curvy, I was putting on way too much to take care of the dry spray. I should have jsut left it. The gfx both got sags in the process, and there's one big one on the bumper itself. I'll straighten them out with sandpaper later on. I used K36 as a wet-on-wet sealer (4:2:2:1 with 2021 clear, no tints) and then sprayed 3 coats of color. I used about half a pint of color to get this.
Car: 1992 Firebird
Engine: forged 357
Originally posted by sellmanb
sexy
oh, the nose looks good too
sexy
haha thanks a lot man, I put a lot of friggin effort into this, so it better look good on the car! lol
1 Post
Car: '86 Berlinetta
I'm sure it will... assuming you paint the rest of the car the same color if it isnt already
That looks very metallic. You didnt use metallic flakes though it looks like. What gives it that metallic look? I am very curious since I want to give the color I'm going to paint my car that sort of metallic "new factory" look.
Car: 1992 Firebird
Engine: forged 357
The car is the same color, lets hope I've got a close enough match!!
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Originally posted by davecamaro
wow!
can u rent paint stations in the states?
great job btw
wow!
great job btw
1992 Trans Am
05-10-2023 07:19 PM
