Mechanic says my car had no "accessories" on the ignition switch
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Background: Ever since I've had the car there has been no accessories access to run the radio, windows, etc with the key turned all the way counter-clockwise. Basically, the tumbler stops at "lock" and will not go any further. This kind of sucks with a convertible whcih can act as a boom box during tailgate season.
Anyway, I've been advised that this could be a problem with the actuator rods in the column from the switch to another switch near the bottom-middle of the column itself. This was that thread not that long ago:
badjuju342 with the good advice on TGO
Yesterday I was sick of it. I wanted it fixed and had a tax return to do it with. He tells me that the marks on the column around the ignition switch inidcate that my car didn't have that option.
This can't be true can it?
With the other members of this forum that have experienced this problem (most being vert owners) I suppose this was standard but I doubt it. I guess if it is not true I will need a specialist to fix this. I'm not comfortable ripping into the column. I've tried once.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If it's true, why not just put a switch in the dash somewhere to turn power on the the accessories?
Car: '91 TA vert
Engine: turboLSx
Haven't read through that other thread but FWIW, I've got an "acc" section on my column. (and I use it quite often for what you want to
). I've never had any problems with it either. Although I've ripped out the "Start" wires from that white plastic connecting in the column to instal a start button.
Are you pushing in (toward the driver side) when you turn the key back to acc?
reading...
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
reading...
reading...
reading...
I think I need a GM dealer.
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
Car: 1987 Black IROC-Z (SOLD)
All 3rd gen cars have the ACC switch on the keyed ignition. Mine is still a pain in the butt to get into though and its been that way since the car was brand new.
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
i dont know if somethings messed up in my car, but the power is always available. i can use the windows and the stereo without having the key in the ignition at all
Car: 91 firebird
kubus_stroinski,
something is messed up with your ign switch. You should not have power to anything but the horn and lights with it off. It would only take 2 seconds for some scum to steal your car (as apposed to the usual 10 seconds)! I would fix that.
Did you drop the column and try adjusting the ignition switcher like they were talking about in that thread?
Car: '91 TA vert
Engine: turboLSx
It's really, really easy to do actually. Something like 8-9 bolts I think. 3or4 for the kneed cusion, two for the cusion bracket, two for the steering column and it drops down IIRC. Then you can stick you head down there and look at the white connector. Good luck.
Car: 1991 Camaro RS
im planning on selling the car very soon anyways... we'll see what happens. i live in a really small town, robbery and theft is very low key here. im not very worried
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Wow, this is interesting... My car has no acc position either, which I always thought was odd... nothing marked on the column like most of the other GM's I've had, so I thought it just didn't have it from the factory. reading the links posted...
Car: 83 Camaro
Transmission: th350
i have found that with well used keys its very hard to get it to acc....yet with a new key it does it with just a little wiggling
has the ignition lock cylinder ever been replaced? I replaced mine and encountered this thankfully before putting the entire column back together. Theres a gear on the cylinder that pushes the rod down and pulls it up. If those two don't line up correctly (as it sounds like yours doesn't) I'd try pulling it up one tooth. I should have my steering wheel off my other column from my project car tomorrow so I'll snap a picture for you to show you what im talking about.
1 Post
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
My camaro has no markings on the column for it eithier. However, it works, you must lock the wheel then push in a turn, takes some effort.
The newest Chevy High Performance on the news stand has a Camaro ignition lock cylinder replacement story in it. How incredibly convenient!
Car: '91 TA vert
Engine: turboLSx
Car: 1991 firebird
Engine: tbi 305
wow it is kinda refreshing and encoraging im not the only one fighting this. my 91 bird also has no markings on the column and i have never been able to "find" the accesory location on it. i think as to save from more headaches, frustration, and outward money flow i am just gonna buy the guys story that my car was not equiped with such an option... love the vert by the way Cadilac
Ghettobird52
07-05-2024 11:18 PM
