sanding curves
Car: Brilliant Red metallic RS T-Tops &
Engine: 305 TBI & 350 LT-1(bolt on's)
Transmission: T-5 & 4l60
sanding curves
ok im getting ready to paint my 4th gen and i need to know how to sand the curves so they dont get uneven and when it comes to wetsanding how do i sand all the curves evenly with the rest of the body???? sorry its not third gen but i can try...when i sanded my 91 RS it was hard too but it was easier than the 4th gen....and what grits should i use on what primer coats and colorsanding coats
Car: 55 Chevy (the only one that counts), 80 TA, 85 TA, 87 FB
Engine: BBC, BBC, SBC, none
Transmission: M-22, TH400, TH350, none
Use a "soft-block" (sb-1) to sand the curves. When sanding, do so in a criss-cross "X" pattern across the curve. Also for tight curves, corners, etc, I have a wedge "DuraBlock" and round (cylinder shaped) "DuraBlock". The blocks can be used wet or dry, and take regular and stick-it style papers. You can find them at a local autobody/paint supply company.
General idea on paper:
400-800 for primer wetsand before paint.
Check on paint manf., some paints dont grip as well as others and need the heavier grit paper
1500-2500 on clear before buffing (depends on clearcoat surface blemishes/amount of orange peel/etc.) .
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
hehe, im gonna paint my IROC in the next month.. Good to know!
Actually, how do you go about wetsanding the clear? I mean, do you use a long block? a short block?? What is the exact technique there?
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I'm ot an expert, but I did see them wet sand clear by hand on the edges and corners of the body as not to "cut through the clear" on television
Car: 1987 Trans Am
Hotrodboba400
12-10-2019 07:07 PM
