'91 Z8 Steering wheel removal
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '91 Z28 Convertible
Transmission: 5 speed
I have a '91 Z28 and the leather has deteriorated at one spot on the the steering wheel and I have determined that it is too expensive to get it reupholstered from the posts on here and have heard that a GM wheel is like $600. I figure it would make more economical sense to buy and aftermarket steering wheel. I like the Grant Evolution GT Wheel part #1080
I haven't pulled off a steering wheel with an air bag before. What is involved in removal of it? I have read something about pulling the fuse for the air bag first. What else is involved?
1 Post
Car: 1991 Chevy Camaro
Engine: 305 TBI
Here's a step-by-step. One note though, you are going to need a special tool, a steering wheel puller. You can buy or rent one at any auto parts store. I know it seems like a lot, but it shouldn't take more than an hour to do:
First, disconnect the negative battery cable. Remove the SIR fuse from the fusebox. Take the knee bolster off (the two plastic pieces under the steering column). They are held in by 5 torx screws. Then, look near the bottom of the steering column and find a large yellow wire. There are two yellow connectors that hold it together, disconnect them by removing the small green piece that holds them together and prying. Now your airbag is disabled. Now you can remove the airbag by unbolt the 4 torx bolts behind the steering wheel (the top left hand bolt is going to be tricky, FYI). Slowly take the airbag out to where you can see behind it and remove the yellow connector from the airbag and the horn button. Make sure to lay the airbag up while it's out of the car just in case it deploys. Then remove the nut that holds the steering wheel on and use a steering wheel puller to remove the steering wheel.
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
Im having the worst trouble getting the bag back on my wheel...any trick to this? The 4 screws are all the way in, due to the little washers holding them in that far.....should I push them out more??
1 Post
Engine: 305 TBI
One word of advice, don't tighten down the bolts one at a time, try and get them all started threaded in, and then tighten them down evenly.
man Im either totally incompitent with attatching airbags to wheels, or Im missing something.....this **** is not workin
![Mad](https://www.thirdgen.org/forums/images/smilies/mad.gif)
backtothe80s
09-05-2015 12:39 AM
