4th gen seats and belt loops
Car: 88 GTA
Engine: 305 LB9
I installed a set of 4th gen seats (94 TA, I think) but they have no belt loop. The headrests look like a deflated basketball not like the thin ones that were on my GTA seats. Anyway, can somebody post a photo of how those loops attach to the headrest. I purchased the correct loops, but any pictures I've seen appear to have another piece that the loop mounts to, as opposed to screwing directly into the headrest. I can post a photo (the car is parked off site or I'd do it now) of the headrest if nobody know of what I write. Thanks as always.
Kevin
Kevin
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
![](http://memimage.cardomain.net/member_images/12/web/660000-660999/660540_66_full.jpg)
they do go directly into the headrest like 3rd gen ones do.....unfortunatly they dont 'split' down the middle, allowing you to feed the seatbelts into the loop. Im still trying to figre that one out....and I may just end up swapping out my new ones for the ones that were on my stock seats
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
Car: 88 GTA
Engine: 305 LB9
Mine aren't cut either. I think I'll do it between the screw holes. My headrests are a little different than that first photo (Camaroguy18), as there is a hard plastic casing around the back half with the leather in the front.
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Axle/Gears: 7.625, 3.73
If you get the ones for a convertible they will have the slits in the bottom of the loop. The one's I got are grey but the dealer should be able to find the color you want by these numbers as they will be close.
#16799316
#16799317
Group # 14.875
Larry.
#16799316
#16799317
Group # 14.875
Larry.
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Unbolt the seatbelt from the floor and thread through the loop, reattach torx bolt. Make sure you have the orientation the way you want it before you tighten everything up or it'll wind up twisted a few times. The loop cracked on my drivers side on my 99 all the time.
Edit: I noticed in the photo that the reel is on the floor and not in the ceiling like my fourth gen. My bad!
1992 Trans Am
05-10-2023 07:19 PM
ambainb
04-25-2016 09:21 PM
