Paint Gun Advise
Car: 88 Firebird
Engine: 5.7 TPI
Paint Gun Advise
Hey guys need a little help deciding what to do. I am almost done sanding my car and about to start prepping for paint. I am about to buy a new Finishline3 and was wondering if I should buy a 1.8 tip for primer. The reason to use one gun for painting and priming is purely budget. Also what size paint tip should I use 1.3 or 1.5? I plan in using ether HOK or Dupont paint. I can’t really afford to make mistakes when purchasing the equipment. Also if you know some cheap online sites for guns and paint please post them? Thanks guys...
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
honestly, there's nothing I can give you for advice. All guns shoot differently. It depends on how you spray. Try a few guns out and see what you like. It's easy for me to say that because I have access to quite a few, but I'm used to SATAjet guns from working with them. If you're on a budget, I've had good experience with Warwick and DeVillbis as well. I've never used a Finishline gun, nor have heard anything about them.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
I just ordered a Finishline, but I'll be out of town for a couple of weeks so can't use it until I get back. Definitely 1.8 for primer, and I like a 1.3 1.4 for BC/CC. Never tried a 1.2, I hear they lay down a good coat. If you use yours before I can use mine, let me know how well it works.
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i have 2 of those exact guns and i used the 1.3 for all steps. it shot perfect. it may not be the proper tip according to the paint body guys. they can tell you that. but i did all 5 steps with the same two guns just cleaned real well between steps.
its a great gun for the money and the weekend paint guys like us.
jeff
jeff
1 Post
Engine: 305 tpi LB9
Originally posted by Token
experience with Warwick and DeVillbis as well. I've never used a Finishline gun, nor have heard anything about them. [/B]
Car: 1992 Firebird
Engine: forged 357
Originally posted by JeffW
finishline III is by devilbiss
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
okay then I have used a Finishline
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
