Drivers mirror glass vibrates
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
Is there a repair to stop the drivers side mirror from shaking/vibrating? Thanks
89 GTA power mirror
89 GTA power mirror
Several years ago, my driver's side mirror vibrated enough to drive me crazy. I eventually discovered that the glass itself wasn't loose but that the entire housing was. Should that be the case with yours, the fix is simple enough to complete yourself: Remove the door panel, locate the two bolts (10 mm if I remember correctly), and tighten.
JamesC
JamesC
Do you have an electric mirror?
I have had this problem on other GMs I have had a power mirror on.
Mid America Motorworks (Corvette place) offers a piece to remedy this. It is a crosspiece that you snap in behind the glass.
http://www.madvet.com/shop?frame=1.2945
Hope this helps.
Edit: I just read that you have a power mirror
Hope this helps.
Thanks for the info, yes they are electric. I have had this problem on another car along time ago, it was under warranty and they replaced the mirror. I will try this for sure.
tglennon11
Interior Parts Wanted
09-11-2015 10:25 PM
