GTA-28 CamaroBird
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
GTA-28 CamaroBird
I'm in the marjet for another camaro, I was thinking about doing something a little different.
I want to take the shell of a GTA, put the front end of a camaro on it, and install the camaro's dash and center console. Effectively making this car a camaro with GTA tail.
Has anyone seen this done? Does anyone have pictures If they have seen it?
I'm very serious about doing it and I want to get an idea of what it will look like when I'm done.
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
It shouldn't be that hard to imagine. You're probably going to get alot of negative posts for butchering such a fine vehicle. And I believe to swap from bumpers you will need fenders and hood as well.
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
yeah, you'll get bashed. It's very doable and similar combinations have been done before. My question is why go with the camaro dash and center console when the firebird dash and console are so much better looking?! hehe
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Do a ! And it doesn't matter what everyone else thinks, it's your car, do what you want. I don't like the Transmaro look, but like I said, it's your dream.
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
its been done before but like gta4me said
1 Post
Car: 86 Transmaro, yes I'm for real do a
Engine: 383, 4 bolt block, scat crank, PM r
Transmission: t5 NWC and its holding up behind my
Axle/Gears: 9 bolt aussie, 3.73s from yukon gea
this is mine, not the best showpeice but I did what I could in a poorly lit dusty garage, and mosquitos seem to be attracted to clearcoat
OUTATIME GTA
Northern California
03-01-2010 07:05 PM
