View Poll Results: Are you interested in an LED 3rd brake ligh setup?
yes
![](https://www.thirdgen.org/forums/images/polls/bar2-l.gif)
![](https://www.thirdgen.org/forums/images/polls/bar2.gif)
![](https://www.thirdgen.org/forums/images/polls/bar2-r.gif)
![](https://www.thirdgen.org/forums/clear.gif)
66.67%
maybe
![](https://www.thirdgen.org/forums/images/polls/bar3-l.gif)
![](https://www.thirdgen.org/forums/images/polls/bar3.gif)
![](https://www.thirdgen.org/forums/images/polls/bar3-r.gif)
33.33%
Voters: 15. You may not vote on this poll
LED 3rd brake light. Any interest?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Need to know if there is any interest in an LED third brake light setup. A friend of mine is making these for the fourth gens and is selling them through the catalogs. He asked if there was any interest in the 3rd gen crowd. The cost will be around $75 or $80 to retrofit the LED assembly into the existing lense from GM.
I'm just looking for interest to see if it's worth his while to manufacture these. If interested, click the poll at the top. Thanks.
1 Post
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
anyway you can wire the tails and third brake light up with LEDs like newer cars? just asking because if you could do a third brake light i figured you could do the tails just as easily but you would need more LEDs.
If there is enough demand, anything can be done. The reason the 4th genners have gone after this is because the brake bulbs get so hot, the bulb socket gets brittle and breaks. The bulb socket 1/4 turns into the back of the lens and that also gets brittle and breaks. The only way to fix it when it breaks, is to replace the lens assembly for $80. Then you need to replace the socket and bulbs. I don't know if the 3rd gens had any problem with that. I do know that the 3rd gen has 5 bulbs that are spendy and this would be a visual enhancement. Just a thought at this point. The LEDs are brighter, instant on and use less current for 5 LEDs than 1 bulb.
Any suggestions?
Any suggestions?
The reason there is not a "No" option is because I am only interested in knowing how many people want this. If you're not interested, then there is no need to reply.
Car: 91 Z28, t-top, 5.7l ZZ4 rebuild
Engine: 5.7L TPI
Transmission: 700r
Re: LED 3rd brake light. Any interest?
Jim
Car: '91 TA vert
Engine: turboLSx
Re: Re: LED 3rd brake light. Any interest?
Originally posted by Brazen
Tell him not to bother. First off... the handful of LEDs you'd need can be purchased for less than $10.00.. but there is a better solution: goto http://www.superbrightleds.com and buy 12v compatible replacement bulbs for almost every light in a 3rd gen. Some crappy pics, but check out my blue LED dash mods (all purchased from superbrightleds) at http://www.fl-thirdgen.org/brazen.html
Jim
Jim
Engine: 5.7L TPI
Transmission: 700r
Re: Re: Re: LED 3rd brake light. Any interest?
Originally posted by iansane
....can you dim your dash lights?
I'm a lil older now, so the brighter dashlights doesn't bother me much. ;]
Jim
Car: '91 TA vert
Engine: turboLSx
Yeah, it was kind of a rhetorical question.
That's the only reason I don't like LEDs in the dash...
Yours looks good.
Yours looks good.
hectre13
12-11-2023 08:14 AM
1992rs/ss
05-19-2020 07:02 PM
