back seat removel
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
back seat removel
how do you get the bottom buckets out..there bolted down somewhere but i couldnt find where...
i just dont wanna taxi anymore and i might build an install back there
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
theres a bolt right in the front of the cushion just look down alittle further. ull find it
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
If you are sitting in the rear seat the bolt would be right between your legs, just beneath the seat cushion. . . IIRC, 13mm socket should do the trick.
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
Pull up on the front of the cushion you'll see it.
Fast355
12-02-2016 06:33 PM
