removing tire rubber from quarters
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
Anyone know what i can use to get rubber off of the rear quarters?
looks like the person i bought the car from was a little to happy doing burnouts.
thanks
thanks
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
I'd immagine that a good "Bug + Tar" remover would do the trick....that and some elbow grease :-P
I've heard that PAM is good for keeping rubber from sticking to body panels.....i guess ya spray it on and the rubber wipes right off......guess it makes senes, lol
Engine: 350 "ZZ4"
yeah somone mentioned bug & tar remover i might try that.
just don't want to screw up the paint.
Car: 91 formula
Transmission: t5
chris... do you remember seeing my quarters when they were covered in rubber from the nats ?
how bad is the rubber ? bug and tar remover will only work till a point and then it is useless lol. i went to autozone and got a bottle of "preps all" its what painters used on cars bfore they spray then to get anything on the primer off.... i just let it soak for a few and then scrubbred it off,a nd worked better then anything else i had tried, and i tried alot.
Rubber removal
Find a cleaner with d-limonene. Citri-Sol?? I had to prep a concrete floor for an epoxy paint and it was the only stuff that could take off the rubber from forklift burn-outs. You may want to try on a hidden area to make sure the paint won't come off. Great for taking off factory undercoating. More info:
http://www.floridachemical.com/whatisd-limonene.htm
you might have showed me pics though, but i forget, haha
Car: 1999 Z28
Transmission: A4
Re: Rubber removal
Originally posted by Briansz28
forklift burn-outs.
forklift burn-outs.
![burnout](https://www.thirdgen.org/forums/images/smilies/burnout.gif)
1992 Trans Am
05-10-2023 07:19 PM
1992rs/ss
05-19-2020 07:02 PM
