seat bolts why do they rust?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
why do the seat bolts and the metal in the center console rust? i'm installing 4th gen seats and is there a way to prevent the bolts from rusting?
Car: Pair of 92 Z28s
i was thinking...like my old truck that had all rusted seatbelt bolts, it went straight through the floorpan and im guessing water or condensation stayed on it under there rusting through...then again that was my toyota pick-up, they are rust buckets to start with
i dunno if camaro seats bolt all the way through or not?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: seat bolts why do they rust?
paint.
i put a GM satin black on my seat nuts, the studs that come thru the carpet, and on the "tabs" of the seat that you can see...
looks like it came that way, and i dont have to worry about thoes stupid plastic cover pieces...
ambainb
04-25-2016 09:21 PM
1992 Trans Am
08-08-2015 08:16 PM
