removing center console
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
Probably a stupid question, but where are the screws holding the center console down? I found the two in the back inside of it, but I can't figure out where its held down in the front. Its a manual console if it makes a difference. I tried searching but got swamped with people asking if 4th gen consoles will fit...
Car: 1990 Formula
Axle/Gears: 3:73 Posi
There is a 10mm under the shift panel area, you'll need to take off the shift panel first ( 3 7mm screws, 2 in glove box and 1 under ashtray) then the 10mm bolt in the middle fo the metal brace, remove the e brake handle and it should come out.
Hope i Helped
Hope i Helped
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
Night rider327
09-02-2015 04:17 AM
