4th gen dash install, Q's
1 Post
Car: '86 Berlinetta
So I have the old dash out, wires laying astrew (and there's not a single "mechanical" device on that dash, since it came from a Berlinetta w/ digital dash, even the heater and a/c is controlled electronically... lotsa wires). I test fit the new dash, it looks great. I know that I'll need to drill new holes for it, and make new brackets for it.
I was just curious where other people drilled holes, and what their new brackets looked like (so I can make them while I still have access to a MIG Welder at school... class ends on the 17th).
I'll post some pics of my progress so far. It's a CLOSE fit with the 4th gen dash in, and closing those doors.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Originally posted by sellmanb
Did you guys take out the bracket completely, and then drill new holes to match with the dash, or vice versa?
1 Post
Car: '86 Berlinetta
Well, after I posted this I ended up going outside and cutting them off with aviation snips (I drilled a lot of holes along the way since I'm not that strong and my aviation snips suck).
This is what it looks like. Yes, that's green spray paint. I wanted to put something over it to prevent the freshly cut metal from rusting eventually. lol.
Transmission: 4L60e
Axle/Gears: 9 bolt
Oh, your talking about that braket, sorry. Thought you meant another. I just cut the tops off like you did and bent the sides slightly inward. I didn't bolt the dash to it at all though. Im using them to pry the sides of the dash out a bit to take up some of the space between the dash and the door.
sorry for the small pics
heres how I just slightly bent them inwards
![](http://memimage.cardomain.net/member_images/7/web/127000-127999/127576_618.jpg)
1 Post
Car: '86 Berlinetta
did you install a firebird dash, or a camaro dash? also, what center console did you go w/ ?
I'm having troubles getting my center console to fit correctly... it's an automatic 98+ camaro center console on a 96 firebird dash... They just dont seem to fit right where the two meet.
Transmission: 4L60e
Axle/Gears: 9 bolt
I have a 2000 T/A dash and 2002 T/A manual console. The 98+ consoles for both camaro and firebird are the same (not counting the manual and auto shifter plate) and all 93+ firebird dashes are the same, so yours should be fitting like mine does assuming you are test fitting the console without the Automatice shifter plate in place or have modded the the shifter to work with the 4thgen Auto shifter plate. (sorry if you knew this already).
How exactly is it not meeting up right?
heres some pics of how mine fits.
Transmission: 4L60e
Axle/Gears: 9 bolt
Have lots more pics of mine click on the link in my sig above and a ton more I have to put up when I get some time.
![](http://memimage.cardomain.net/member_images/7/web/127000-127999/127576_749_full.jpg)
1 Post
Car: '86 Berlinetta
That's kinda what I meant there hehe. Seems the dash doesnt go back far enough. In that picture it's not supported up except by the center console lol.
Later from that picture I drilled out the new holes for the dash, which might have made it a little better, but I couldnt get my center console back in after I hung it (I am assuming that I need to put the console in before the dash).
I couldnt really tell how yours' sat, because of all the black on black (which is what I'm gunna paint mine after I get it all figured out lol).
Transmission: 4L60e
Axle/Gears: 9 bolt
Transmission: 4L60e
Axle/Gears: 9 bolt
Originally posted by 1bad91Z
How did you get the headlight / AC / etc.. controls to work? Or do they?
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
