seatbelt jammed!?
Old 03-03-2005 | 10:35 PM
nates's Avatar
seatbelt jammed!?
my driver side seatbealt is fully extended and wont recoil back tight, any ideas on how to fix this?? thanks guys!
Old 03-03-2005 | 10:46 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
What year? Some of the early to mid 80's models had problems with the retractor spring poping off and the belt wouldn't retract back in.
You can pull head liner down slightly and look up at the retractor. The spring assembly is a round plastic peice that is attached to the seat belt retractor. Make sure its tightly in place. If it popped off, wind it so there is some tension when the belt if fulling retracted and then line up the pegs and press it back into place.
xbazzarex
12-01-2015 05:25 PM
SRKLEGIN
Interior Parts Wanted
10-12-2015 07:28 AM
SRKLEGIN
09-30-2015 07:19 PM
FormulaEngland
09-30-2015 01:50 PM
Quick Reply: seatbelt jammed!?
