power window talks?
Old 03-03-2005 | 05:59 AM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
power window talks?
i got an 83 with pwr windows and evertime they are going up or down (really slow) they make a strange humming sound as they go up or down.
is this from the motor or the tracks? do the tracks just need a lube up or something like that? anyway i want it to stop, what do i do?? any info on this would be great, thanks in adance
Old 03-04-2005 | 08:27 PM
AJT86's Avatar
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
well if they are going up and down slow to begin with- get new motors- its not a fun job but youll like it alot better when its done, when your installing new motors take the regulator assembly out and check it and grease it- if it all looks good then put it back in.
Old 03-04-2005 | 11:32 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Replacing the motors is the last thing you should try. Checking grounds, switches, and greasing the track should be first.
Old 03-05-2005 | 07:34 PM
AJT86's Avatar
well if your motor is whineing- its not going to be the switch, every 80s GM ive ever owned have had motor failures. if they are going up and down slow its a motor problem. usualy when a regulator goes- it makes a clicking sound, but thats just my day to day expeirience at work.
1992 Trans Am
05-10-2023 07:19 PM
Vintageracer
01-10-2020 05:33 PM
RedLeader289
01-22-2016 03:05 PM
IROCZDAVE (88-L98)
09-13-2015 09:07 PM
stalkier
08-21-2015 01:54 AM
Quick Reply: power window talks?
