im putting in a new floor pan advice please
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
im putting in a new drivers side floor pan anybody with any advice before i cut the huge hole in my car thanks
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
cut the hole smaller than you need then trim it a little at a time till the peice fits in nicely ....also use seam sealer.....
Car: 85z28,
cut once measure 2 or 3 times first. Clean all the metal were u are going to weld. Use a good welding primmer. Use a good 2 part seam sealer.
