NEED HELP!Gauges
Car: 89 t/a
NEED HELP!Gauges
alright I just made some new gauges and when I turn the car on now my fuel, oil pressure and battery needles dont work at all please help!
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
what do you mean you "made" new guages? do you mean you printed out overlays- if you made overlays and you didnt unplug your cluster- the needles are problably hitting the paper- and flatten it out- if its not that- you have a bad electrical connection to the cluster, if its an electronic cluster.
Car: 89 t/a
yes they were white overlays and they stayed pretty flat, where do I unplug the gauge cluster? is it screwed up if I didnt, will it reset if I unplug it and plug it back in? I checked theyre not hitting the paper.
jason
jason
well if you have an electronic cluster- when you pull the cluster out it disconnects, are they moving at all- when i put my overlays in my water temp wasnt working right- so i pulled the needle off and pushed it back on half way and it worked great. are you getting any movement at all?
Car: 89 t/a
rpm and mph are fine, voltage works if I put it on halfway no fuel no oil and temp will move a little when ignition is turned thats it, I didnt see a cluster to disconnect but Ill check it out again tomorrow I guess I'll take it all down again, is there any way to get these to light up a bit better? thanks yall
Jason
Jason
yeah it sounds like your needles are hitting the paper- pull the needles out- make sure the pin that the needle attatches to isnt hitting paper- then put them all on lightly- if thats not it- then your needles are out of place maybe- i had to redo my tach- it said 0 untill i hit like 3500 rpm somtimes when putting the needles back on your turn it by accident
