getting seats out
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
getting seats out
OK heres my situation. The guy who owned my car before me didnt take very good care of it. The nuts that hold the seats down on the drivers seat are totally rusted to the bolts. I think ive succeeded in strippin the outside nut on the drivers seat at the front. No if i have to hack this off with a Whizzer wheel or sawzall, is there a way to attach another bolt through the floor so that I will have something to attach the seat to? IS the bolt that is coming up through the floor part of the floor pan? or is it welded? Thanx.
Car: 1992 GTA
Axle/Gears: 4.10
The bolt is welded into a rail that in turn is attached to a brace thats welded to the floor pan. You could cut it off and weld another stud back on but it might be easier to try to salvage the original stud if possible.
Car: 89 Camaro RS
Engine: 305 TBI
I agree wd40 did wonders.. mine where rusty too.. soaked them real good. and once off took a wire brush to the stud to clean it up. now they are all fine. I also put some anti-seize compound on it before tightening them back down.
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
when they say soak it, they mean soak it... try spraying the sucker maybe 3 times over the course of a day, let it sit over night, and try your luck with the vice grips the next day... if that doesn't work, try and hammer a smaller sized socket onto the bolt and using a ratchet... as a last resort, you'd need to cut the thing outa there and weld on a new stud. If you can weld, or you have a friend that can weld, that'd be pretty convenient.. however, you could probably get some guys at an exhaust shop to do that for you if need be...
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
craftsman has a socket specifically for rusted and stripped nuts...it literally cuts into the bolt to get the best grip...use those and wd-40. good luck
1 Post
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I have to admit the craftsmen damaged bolt out remover does work well on other applications that i have used it on, Never tried taking my seats out so i cant see it, but it might be worth it to spend $20 and get it.
thanx for all the replies, IM gonna hit it with the GM Rust Penetrant, and WD-40 and Liquid wrench and anything else i can find and im gonnt beat the crap outta it for good measure, and try vise grips then ill prolly break down and get one of those craftsman sockets.
