Dash removal?
Old 02-20-2005 | 07:06 PM
bac67's Avatar
Car: 91 Camaro
Engine: LO3 305 TBI
Transmission: 5 Speed
Dash removal?
To completly remove my dash wats all involved? anyoen one have a good explenation of takin it all out. do i need to remove the steering wheel? center console? ect.
thanks
Old 04-25-2005 | 01:59 AM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I also need to do the same thing. Can anyone help the both of us please? Thank You.
Old 04-25-2005 | 09:12 AM
budweiserbeauty's Avatar
Car: 1988 Formula
Engine: 5.0
the other night i took half mine apart. under the dash pad, theres a bunch of screws, also under the middle trim (hatch, rear defrost buttons) under that. i only removed that trim piece and my gauges though. gauges were tricky to get out around the steering wheel. hope it helps a bit.
Old 04-25-2005 | 10:26 AM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
4 screws in the front defrost vent, and about 8-12 screws under the dash, then you just slide it off.
Old 04-25-2005 | 12:06 PM
devianb's Avatar
I had attempted to do that, a hell of alot of screws to take out, I only managed half of it and got tired and put it back in as it was getting dark.
Old 04-25-2005 | 03:52 PM
Guys, I really think I have to pull the whole dash out from the firewall not just the pad. The pad is extremely easy to remove. I meant the whole dash and what holds it to the firewall.
Old 04-25-2005 | 07:44 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
just part pulling screws.... everything has to come out so just start unscrewing everytthing, and you dont have to pull the column, but you do have to lower it and it involves takign out the 2 bols around the center of the colum under the dash
Old 04-25-2005 | 09:22 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
There are screws that hold the air ducts to the back of the vent openings, and you kind of just have to wrestle the dash off of that. Taking off the dash isn't too hard, just remove all of the screws (theyre all over, there are some behind the HVAC and radio area, under the dash the whole way, on top of the dash, etc.). If you see a black 7mm screw, take it out, cuz, chances are, it'll help.
Also, if your steering wheel is still on, its more difficult. You have to tilt the wheel all the way down (past the point where it locks) and jiggle the dash from behind.
Vintageracer
01-10-2020 06:33 PM
Eric2ndGen
11-05-2015 02:51 PM
Street Lethal
08-14-2015 09:25 PM
stalkier
08-13-2015 01:59 PM
3rdgenparts
08-08-2015 08:09 PM
Quick Reply: Dash removal?
