The Weight Reduction Thread!
#551
Car: 1986 Firebird
Engine: 5.0L V8
Re: The Weight Reduction Thread!
you want to use "like" metals. Thats why I was told to never use metal valve caps on TPMS wheels unless they came in with them on lol
#553
Car: 1987 camaro sc
Engine: lg4 305
the way to get around this is paint both the steel and aluminum so moisture cant get inbtween the aluminum and steel and cause it to corrode the aluminu
#555
Ok I've been working on lightening up my front end and little by little it's coming together. Right now I have my eye on a front disc brake kit that weighs 33.5 lbs. and that includes the four piston calipers, ceramic pads, the rotor, and the complete hub with bearings and all. My question is, how much of a weight savings is this? How much does the entire above mentioned STOCK assembly weigh?
#556
1 Post
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Zombie thread
https://www.thirdgen.org/forums/post...9-post391.html
I just remembered today after looking something up that I was going to share Blackenbird's spreadsheet. Here's the google doc's link:
https://docs.google.com/spreadsheet/...kE&usp=sharing
Let me know if it doesn't work. I'm not particularly interested in updating it, but if somebody wants to I'll add them as an editor or they can create their own sheet.
#558
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
my 4th gen t/a power leather seats with 3rd gen tracks were 53# driver 33# passenger.
#559
Car: 1987 Trans Am and 2009 Jeep Patriot
Engine: 305 Tpi
Here's some weight reduction, I was doing some work to the rear wheel-houses, some of the undercoating, dirt was over quarter inch thick in some places. Judging by the weight of the garbage can, I removed at least 20lbs of crap. Besy way I found to get it off was to use a slightly dulled blade in the sawzall, bend it in the middle, it started falling off in chuncks
#560
Engine: 305 Tpi
Offhand anyone know the weight diff between aerowing and older 2 post spoilers
#561
Finally got to weigh my cloth power seats. With the seat and the rails is 53lbs per seat!
I bought kirkey pro street alum seats and they are 15lbs with the cloth cover and without the seat rail!
Also weighed my stock rear carpet = 13lbs
The upper back seat weighs = 22lb
The lower back seat weighs 4lb/piece
Anyone know how much a stock gas tank weighs?
Any benefit to a getting a fuel cell?
#563
Axle/Gears: 10bolt4life
Aren't there metal supports attached to the dash or are they left behind in the car? I can't remember. When I removed the dash from my camaro I remember it being rather heavy. I would have assumed more than 26lbs...
#564
This is on a 1987 GTA budget bracket build we're doing. We wanted to take as much weight off without losing function of the power windows. We got the driver's side door lightening done. 15lbs saved out of the door itself. the c-channel crash bar is 12lbs by itself. i highly recommend removing it if you have door bars in your roll bar.
this is the passenger's side door, which i haven't touched yet.
here is our driver's door in the "after" state.
#565
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
good lord matt. my door sounds hollow as it is when it closes and its all stock. i bet it sounds like kicking a can when you close it now.
lots of work, but 15 pounds a side? worth it!
did firebirds or different years get an updated crash bar? all the ones ive seen are tube. mine is tube in my car.
the one in the pass side pic looks like some kind of hat post or channel, which im sure is up there in weight over tubing.
#566
Car: CTSV
Engine: LS6
Where is that excel spreadsheet? I am thinking about picking u a 92 V6 Camaro with no options or a dedicated drag/Mile car.....she needs to be very light.....2800 would be great with my 200lb ****.....
#567
#568
2800lbs with 200lb driver is going to be a stretch on a stock type suspension/stock floor board thirdgen, but not impossible. tubular chromoly everything, lexan, fiberglass, and attention to details will get it there. you must look at every part of the car and determine if things can be trimmed, drilled, removed, or replaced with something lighter. being THAT light is a lifestyle, not something you can do on accident, lol. if 200lbs is as light as you personally can get then you have a big task on your hands. i have personally lost 65lbs in my quest for being lightweight. my end goal is 3000lbs with me in the car. currently i'm 250, but hope to be 225 by the time racing season starts. i believe i can get to 3100lbs with driver this year as a result of my latest lightweight efforts.
#569
Car: CTSV
Engine: LS6
Fo Sho!
185 is my fighting weight at about 9% body fat, so yeah.....lol
My 1992, no option B4C weighed 3300 with me in it, but I was 160 back then....lol
#571
Car: 1990 gta
Engine: 383,tfs heads,hsr
Axle/Gears: 12 bolt 3.73
finally I got to weight my car today after all winter taking some weight out....
it came at 3090# without me im 180#
I lost about 177# from last year.
#572
Car: 1985 firebird
Engine: 360"sbc NA pump gas
Transmission: Th350 manual valve body
Axle/Gears: Moser 12 bolt 4.11:1
2970lbs with out me
Stock k member, 8 point chromemoly cage racing seats factory carpet 4gal cell, S&W anti roll bar. Moser 12bolt
#573
Car: 1990 gta
next things on the list are
*remove stock front seats for lighter ones
*remove insolation between the carpet/floor
*rear crash bar removal
#574
Car: 1985 firebird
Who's k member and rack and pinion you using?^^^
#575
Car: 1990 gta
the k member and a-arms a good friend of mine did it, he's done like 10 or so for his customers...he has a chassis/fab shop.
the rack I got it from ebay for $74 I mounted myself and I fab the steering linkage and tie rods.
I used to have manual box...im glad I went to rp waaayyy nicer feel on the road.
between k member a-arms and rp I saved about 120lbs.
#576
Car: 1985 firebird
Thanks for the reply,
That's my next step is the bmr k member coil over,,rack and pinion,strange brakes kit.
#577
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
#578
old thread but i ask anyway. does anyone knows what 4th gen seats weigh with 3 gen sliders vs 3th gen stock seats? by the way, is the rear seat on a third the samt as a forth gen?
#580
Did you use manual sliders? Is it any weight difference between 4th gen back seats compared to 3th gen? Or any difference at all? Just wondering why anyone want to change if so
#587
#588
I plan to return to the scale to take a picture because i forgot but i really dont find the stock hood to be that heavy. The rear hatch tho, that thing weight a ton!
#590
Engine: 4++,350 & 305 CIs
My Aluminum 82-4 trans am 87-92 formula hood weighs 20-21 lbs
#591
I'm building a street/strip car. No A/C, heater, PS, wipers, front sway bar, etc. Is it illegal to remove the front bumper/crash bar? Only be cruising the streets on weekends and down to local track.
#592
1 Post
Car: Lots of 'em
If it is, my state owes me a few years worth of fines I suppose, even though it wouldn't be hurting anyone except for myself. I haven't had crash bars or sway bars on my daily driver in about 5 years. Or the car that's being built. As long as you're fine with the risk, I don't see the harm. I'm not having any real luck on finding any laws on the matter right now. I'll have to do some further digging.
#593
It's kool! I just wanted know how many have done it. Like i said its gonna be a weekend cruiser into town and down to the track. Is it a simple unbolt and everything bolts back up no issues? I've read its like 25lbs? Old girls definitely shed some pounds lately.
#594
I realize this is an old thread but I’m sure it’s always referred to. Here is the difference between a stock battery & lithium battery (18lbs)
#597
Yes it’s very powerful and even has “jump start technology” in it. It comes with a remote control like a car key fob. If it ever dies, simply press the button and it restarts itself. I’ve only had it for a couple months but so far it’s like a reg battery, just HALF the weight. They are very pricey though, $750!
#598
How is that possible (for it to just jump start itself?) Is there some backup internal battery inside that holds a charge only when needed with the button? If so, then that's an extremely cool design, but yes, pricey. Lithium batteries last about the same as lead acid ones though IIRC.
#599
#600
COTM Editor
Received 1,941 Likes
Car: '89 Firebird
Engine: 7.0L
Li-ion batteries have a waaaaaaay longer service life than flooded lead acid batteries. But they have to be treated right to get there.
