question on steering wheel compatibility between different years
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I found an NOS steering wheel, Gm part # 7983240. Does anybody know if the splines on the steering columns are different from year to year, or will any of the thirdgen steering wheels mount to my 85 column? If anybody has a way to tell me exactly what this part number is for, I'd appreciate it, as I can't find any info. There is also a chance this might be out of a Fiero; would this still work if this was the case?
Thanks,
Eric
Thanks,
Eric
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
from what ive experienced all our columns from 82-92 are the same. they have the same splines so all wheels interchange. not to sure about 4thgens tho i had to grind a grrove on my 4thgen wheel to get it to fit. any thirdgen wheel should fit any thirdgen column
matt
matt
matt
matt
yea itll fit most gm's up til the mid 90's used the same column with the same splin as our cars should just bolt up.
matt
matt
