Q about 87 base camaro GFX piece right behind front tire
delete
thanks
thanks
Car: Camaro
Engine: worked 350
Transmission: automatic
Axle/Gears: 3:73
As far as i know, my base model sport coupe has no GFX its just plain, but the iroc-z z28 i parted out for all the body components, the GFX has a recessed area for the Z28 emblem that is just taped in.
taped in, hmm
what color/type of tape ?
double side body tape ? white ?
thanks
thanks
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
If there is an emblem in the ground effects on an '87, they should not be held in with double sided tape....
On the back of the emblem there are 2 tabs that mount into the holes on the ground effects. This is what holds them on. If they have tape, they were prolly broken b4 and this is how someone reattached them.....
Never heard of them held on with tape B4
thankjs
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
Re: Q about 87 base camaro GFX piece right behind front tire
Originally posted by Fast68
on 87 base camaros, the short gfx piece attached to bottom of fender right behind front tire, did they have a spot for a badge in them or were they smooth no badge on base model ?
1992rs/ss
05-19-2020 07:02 PM
