Besy way to route wire to under the car..
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Ok, I did a bunch of searches, but none quite answered all of my questions. I have it all figured out, except for one thing:
I bought an electric exhaust cutout, and have been preparing to install it. I have the switch mounted and all that, but my problem is that I cannot seem to find a good/easy place to route the wire from the centre console down to the cutout where the cat used to be.
It's an automatic, so I was expecting to see a rubber boot directly below the shifter where the cables go through, but this is not the case. So what's the next best place?
The goal is to not have to take a lot of stuff apart to do this.
Thanks.
Thanks.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Why not just drill a small hole, put in a grommet, and run the wire thru it under the console? On the passenger's side would probably work best to access once under the car....
Transmission: 5 spd
Well that'll be the worst case scenario. I would just really rather not have to drill a hole.
1 Post
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
This pic will give you an idea where my cut out is...I had a Qtp electronic valve on it till it died.
What I did was face the cut out valve solenoid so that the wire was going out towards my gfx...I then fished the wire into the gfx and zip tied in place. Then it was run thru the gfx up to the frt fender area behind the tire. I fished from the gfx thru a hole in the fender up behind the fender. Then I found the hole where the antenna wire used (shaved now) to run thru into the car. I fished it thru that hole into the car and behind the kick panel and up into the underside of the dash, the panel above your feet. Then I ran it over to the radio pod. Tucked it back behind it and under the edge. Then keep tucking it as I went to the center console and under its edge. Then I ran it along the center console. I pulled up the center console shifter plate and pulled the wire and slipped it bw the center console shifter plate & the and console glove box.
Hope that helps!
Hope that helps!
Transmission: 5 spd
Hey thnkns for the help. I can visualize all of it save for how it goes from the gfx into the fender, and how I might be able to get that wire to go from the radio pod to the console with that huge clip on it, bit I'm sure I'll figure it out.
..iIf not, then in a week or so you will all be hearing from me again lol.
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i would just drill a hole through the floor. not like your drilling a 2" hole or anything,.
1 Post
Glowsock
01-09-2017 04:06 PM
