t-top compatability
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
t-top compatability
Does anyone know which year tops are interchangeable? My 92 Z has the Lexan tops, but one has a crack in it. I tried the glass tops off my 84Z but it doesn't latch. My 92 is a daily driver,so any help is appreciated before the next big downpour
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Your outta luck.If you have lexan t-tops.That means you have after market t-tops an were not factory ordered.Only the lexan tops will work for your car.And are a bitch to find in good shape.Sorry
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
That's not true....there were factory Lexan t-tops for one year I believe.
The difference between years is the hook or pin style tops. Although I think my t-tops are a bit of an anomally because I have an 82 and replaced a t-top with one that came from an 85 and if fit. Supposedly only 82-84 should of fit for my car...so I don't know what's up with that. Although I believe you can retrofit, you just have to also get the mounting brackets. Therefore in theory any t-top should work hook or pin of you also get the brackets that are under the trim pieces.
check here..he has a set of Lexan t-tops for sale
Third Gen USA
He is a reputable third gen parts dealere here in So Cal.
Third Gen USA
Lexan tops aren't all aftermarket. Where'd you get that information?
CC1 is the glass t-tops RPO
CC3 is the plastic.
The 84 and 92 t-tops won't interchange because of the piece that the latch pins mount to on the body. You need to swap them as well, which requires removing the interior plastics that cover them.
CC3 is the plastic.
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I had Large pin stock Lexan t-tops for my 89 bird. I bought small pin glass t-tops from an earlier camaro. Works great.
Thanks for all the info guys. Helps alot.
Oh, and the lexan tops are factory; I double checked my RPOs.
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
CC3 is the plastic.
CC3 is the plastic.
I have a spare pair around here somewhere, I was going to put them into my car until I figured out I needed the sockets.
Car: 91 firebird now
Transmission: 5 speed
don't mean to bring this back from the dead but does anyone know if you can take the t top latch part off and swap it from another style t top ?Like removing the glass and using the whole other bar off a broken t top?
Car: 1991 Red Trans Am
Transmission: 5 spd manual
Actually I think you can! I was looking some glass tops for my 91 TA and found some... I was going to have to switch out the trim and all, but I found some... so , if i remember correctly I am pretty sure you can.
If I'm wrong.. I know someone out there with much more knowledge will correct me if I am wrong!
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
Thirdgen89GTA
11-26-2015 11:04 PM
