Interior Pics of Manual Cars....
Car: '91 RS, F41
Transmission: WC T5
Post some pics of your interiors with manual transmissions... im interested to see what different kinds of shifters and shifter boots look like. Anyone done anything unique with their console? Posts pics... later
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
heres mine hurst shifter, hurst ball, stock boot. dont mind the beat lookin steering wheel its gone now in favor of a 99 z28 air bag wheel
Car: '91 RS, F41
Transmission: WC T5
Baby Lou, is that the hust leather **** with the "H" on the top of it? I was looking at one for the stock shifter... they look good.. Camaro 88, you was right, that **** does flow well with the console.Camaro 430, do you like your hurst shifter? i have heard alot of good things about them...
yea i love my shifter. its a hurst competition plus. the only complaint i have is i want a shorter stick. im lookin now for replacment sticks for it. shifts awsome tho and the white ball with the black 5spd pattern give it a lil muscle car look
Car: '91 RS, F41
Transmission: WC T5
is it just me, or is there a muscle type look to any car with a stick shift when you look inside it?
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
And especially since the "short-throw wannabe" Hurst shifter had a very long throw, I just got pi**ed and shortened it (cut it in half). Feels MUCH more like a sports car now (instead of like a truck).
Hope this helps.
Lou
P.S.: You can see pics here in my album.
Car: 2004 Pontiac GTO
Transmission: M12
Originally posted by adambros
Hurst Pro Shifter (Stock cheapo plastic ****)
Momo Millenium Wheel
4th Gen Ebony Pwr Leather
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Originally posted by z28kindaguy
I'm loving that Momo wheel. May I ask where you got it and how much it cost ya?
If you've got a factory installed airbag you may also be interested in my post about install issues.
https://www.thirdgen.org/techbb2/sho...hreadid=266371
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I made my own shifter... a couple times!
This one is for the T5 I'm using now. I haven't done anything with my 4-speed yet, as its still sitting in a box in my basement
This is the stock T5 handle I modified when I got bored one day... I chopped off the top and welded on a 1/2-20 thread so it would fit basically any **** out there (you can see where it narrows down near the top). This pic is from when I just got the welding, grinding, etc.. almost done, just needed a little cosmetic work and paint.
I also curved it back a bit, because I thought it looked kick ***! Feels really cool too, way better than a straight stick... if you've driven any muscle car with a curled back shifter, you know what I mean
Transmission: M12
http://www.ltbmotorsports.com/millennium.html
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
heres mine and yes i know its dirty. IM gonn abe puttin seats and stuff in so i se no point in cleaning them right now.
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
Mine is a stock 83 shifter, shortened 1", with a stock boot and an 84 ****.
Looking for the day to install a Hurst
Car: 1985 Iroc-Z
Transmission: t-5
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Hurst Billet Plus shifter
Leather "H" Hurst **** (installed backward in this photo, turned another half turn in real life)
Shortened lever
Factory 2002 Firebird console and boot
Shortened lever
One more shot showing where the mirror switches are...
1 Post
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
okay i was kinda keeping this under wraps untill i finished it but this thread came along and i decided i could give you guys a sneak peak
its an overlay i made for the stock shift pattern, all my numbers are worn off on the stock one. its white platic with a design printed on top, used an engraving machine in our machine shop, engrave the surface with a shift pattern and viola! a simulated carbon fiber plate with an engraved shift pattern that will never wear away and will always look good.
in a few weeks all the panels on my dash with be made out of this plastic, then ill be the only 3rd gen with a simulated carbon fiber dash insert kit (i think????)
1 Post
Car: 1984 Z28
thats because the camera was 3 inches away, when your sitting in the car and your 1.5-2 feet away it looks like carbon fiber, thats why its called simulated carbon fiber. same thing in my moms 2004 Envoy, it came with 'simulated carbon fiber' from a distance of a few feet, like in a regular normal sitting position it looks like carbon fiber, but you get close and see that its just little different colored triangles
Originally posted by ator
Engine: L98, Hemi 6.2
Thanks for the compliments, Nick! The seats are from a 2000 Firebird, gray leather with driver's power. Console is an actual 5 speed console from a 2002 Firebird (from a V6 car). Took a long time to find that one! But worth it in my opinion.
The window switches are 3rd Gen mounted on a plate attached inside the ashtray.
The mirror switch is 4th Gen attached to a plate I mounted in the front cubby hole.
Again, THANKS!
Again, THANKS!
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
ok i gotta jump in here, dont mind the mess, just installed a pro 5.0 and i LOVE IT!!!!
1992 Trans Am
05-10-2023 07:19 PM
ambainb
04-25-2016 09:21 PM
1992 Trans Am
08-08-2015 08:16 PM
