new on the block w/cupholder?
Transmission: TH200C....700R4
Hello everyone,I recently went to pic a part and saw some cool cupholders on the door of a 92 firebird.I know my 82 firebird s/e did not ever have any but I got them anyways and before I take my interior door apart to install them I was wondering if they will even have a place to bolt on my door .
thanks,Rich
thanks,Rich
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
If they fit on a 92, they should fit on your 82. The ones on the 92 can't possibly be stock, since our cars never came with stock cup holders.
Car: 84 T/A 70 Chevelle SS 78 T/A
Engine: chevy 383 Chevy 496 Pontiac 462
Transmission: built THM700r4 Richmond 6 built TH400
Axle/Gears: 3.45, 3.27, 3.27
They will fit on your car, but your inner door panel won't have the square holes that were punched into the later model doors (90+) to attach it to. This is not a problem. All you'll have to do is position the cup holder with map pocket onto the door, mark the location then drill through with a small drill bit. Remove the door tim panel and drill a larger hole for your screw. The OEM method of attachment pops a white plastic insert (commonly used to attach license plates) into a square hole. The screws that attach the cup holder attach to those plastic inserts.
Lon
Lon
thanks Lon, I know everything I need to know now to install my cupholders.I know what you mean about those plastic shi##y
tabs.My armrest/door handle use to have those and they stripped right out,I remounted the armrest/door handle with toggle bolts and there strong as all hell and you cant even notice the difference visually.
Engine: L98, Hemi 6.2
Originally posted by Metal383
Later thirdgens had optional cupholders. Got a factory set in my 91.
really?? I thought no 3rd gens came with cup holders, thats cool tho
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
FYI installing these in Camaros requires fabrication of a mounting plate for the top screw, as it is located in an empty area of power window doors.
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
They were only available on some later GTAs and thats it I think...not on any Camaro.
Hey I'm in L.A. and I have an 82 TA too =)
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Car: 1992 Jade Green---Trans Am Converti
And here's what most driver's sides look like.. (the cp holders tend to break pretty easy over time)
At least you can see the three holes needed to attach.
Yeah....those are the same ones I got at pic a part,same color and everything.Except that color wont match my interior so I am going to spray paint them black with krylon fusion.That sh&* works good!
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Originally posted by 82knightrider
My cat K.I.T.T..........
LOL its a K.I.T.T. cat......LOL
skinny z
10-05-2015 06:23 PM
