Map Light internals missing....how to fix??
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Camaro
Axle/Gears: 4.10
I got this light and connector on ebay and can't see an obvious way to install it. I figured that this is what I needed since there is nothing at all behind the swival map light. I would think that you would need to take off the overhead console to put it in. Any help on putting this in would be appreciated, thank you.
Car: 1986 Camaro
Axle/Gears: 4.10
The above picture is what was behind my swival map light. This picture is what I bought to fix it...
Mine looked exactly the same I got the little socket from a local yard but when I took console off I found the original socket inside so check it's probablly still in there. The way it installs it can't really just fall out.
There's some info on the following link that might be helpful:
https://www.thirdgen.org/techbb2/sho...threadid=99782
JamesC
JamesC
ambainb
04-25-2016 09:21 PM
