half a paint job??? why???
#51
and why doesn't any of these shows ever do a TPI !! always carb'd... !!!!
#52
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
Carb = Nostagia & Ease... if they are on a time limit, do you think they wanna worry about rewiring a TPI harness?
#54
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
the saying is called KISS....or
keep it simple stupid
that's why carbs work easier, tell me if u'd like to be working on a horendous 1980's designed fuel injection unit.....i don't think so.
#55
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
As a result of these remodeling car shows and the related advertising, everybody and their grandma will want to "pimp their ride". Soon there will be a Pimp you Ride isle in wallmart.
I guess I'll have to buy a new boring car annd keep it bone stock in order to stay punk. that bland so callled gto could work.
BTW: The entire point of customizing/ hot rodding is to do it your self. It's not the destiation that is most valuable but the journey young grasshoppers
#56
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally posted by 91formulaSS
How do you powder coat a car?
Not sure what show but they did up a dodge charger for Joe Rogan. They powder coated the inside and under body on the show.
You could also do it the slower way. with an infrared lamp and cure each small section at a time.
"This Car Was Powder Coated With Our Super Mirror White Along with the Candy Red and Cured with The Infrared Heater!!! "
#57
Car: 1987 Camaro IROC-Z
Engine: LB9
i've never seen such shows, but i know they only have an hour or so to show a beat car driving / towed in and driving out a beautiful car, its more then possable that they cut corners and i'm sure it hapiens, as it was said the shows are for entairnment purposes and for free the owners really can't complain much, however its possable that they just don't air the "boreing" stuff like cleaning and preping the engine bay for paint and painting the door jambs.
Hotrodboba400
12-10-2019 07:07 PM
