what size torx for cluster removal?
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
i searched and didnt come up with anything. i dont want to strip the screws out by using allen wrenches so im wondering what size the torx is for the interior pieces, it looks small like maybe 5/16ths? if someone could confirm this for me so i can go out and buy the right size that would be awesome, thanks
Car: 1991 Chevy Camaro
Engine: 305 TBI
I'm not really familiar with earlier 3rd gens, but Torx bits are actually rated in units of 5. For instance T5, T15, T30, and so on. Id just buy a set of them, they're not expensive at all (a set of T10-T45 can be as cheap as $8).
I've been using allen keys on those interior torx screws for years and never stripped them. If the screws strip, it's not an actual screw, just decorative plastic. Move on to the next screw and your panel will eventually come off.
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
All those little dash torx are T15's FYI. Every craftsman ratcheting screwdriver I've purchased included one in the assortment...
Otherwise just get a bit...
Yup there are a few fakies in that dash though...
Car: 1984 Z28
i shouldve known that! now that i think of it i have like 5 of those screw drivers with the torx ends on them. oh man i feel stupid! thanks guys!
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Depending on what you are doing with the cluster you may also want to have a 10mm and 5.5mm sockets handy.
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Be careful with the torx screws. Most of them on the trim are fake. In fact I'm pretty sure all of the torx scews you see on the instrument pannel bezel are fake. The bezel is actually held on by screws at the bottom, but they are hidden by the lower dash trim. You'll have to take those off first. Those are held in with screws underneath. I think both are 10mm but could be wrong. I found out the hard way about the fake torx screws by stripping out some on the console. Just don't turn the torx screws hard. If it doesn't come loose easily it is probably fake. They are plastic and should come out pretty easy so don't force it unless you want a crappy looking trim piece. By the way, most of the torx screws are T15
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Car: 1982 Trans Am
Engine: SBC 400
Originally posted by ES87iroc
Every screw holding the 82-89 instrument panel is a real metal screw. However, the left and right light and switch pods do have some of the plastic fake screws, but you do not need to remove those parts to pull the cluster out.
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Ah, yeppirs, the info I posted is about camaros from 82-89. I thought that was what the original poster had?
toronto formula
11-10-2015 06:17 AM
knight72
08-10-2015 09:32 PM
