And up next....door panels
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I really need some input here. My interior is bascially done...besides the door panels. I wish I could switch to the 4th gen door panels...but..I heard they don't flow with the 3rd gen dash. What I'm trying to do is to get the hairy, carpeted look out of the car (minus the floor carpet)...that's why I modified my hatch area...to give it a more updated look. If I were to recover the entire door panels with just graphite/ebony vinyl...I'm afraid that would look really plain or boring. Do you think I should just cover the lower portion of the door panel (which is carpet) in vinyl...or should I just spray it...with the ebony/graphite spray? As you can see in one of the pictures...I sprayed the kickpanel carpet with the spray...and actually doesn't look bad....
btw, the carpet looks like hell because of the flash....I should replaced it before I installed the roll bar...and the mega shifter..
Car: 1987 Iroc Z "Classic Roc"
Engine: 5.7 350
Get yourself a good set of thirdgen GTA panels. They are mostly vinyl. Then replace the small fabric portion at the top with vinyl in a different color. I did this in black and grey. The nice thing is you get the map pockets too.
Engine: 5.7
that's something to consider USA-1. Are there certain years that look better...or are all the GTA door panels the same? Also..what does the lower half of the door panel look like?
Engine: 5.7 350
I think all of the GTA panels are the same but I could be mistaken. The lower part is rug but I would say it's only 1/3 to 1/4 of the panel. A lot of that is taken up by the map pocket so it breaks it up nicely. The upper portion around the door lock and handle is fabric but that came up pretyy easily. I just sprayed it with 3M 90 and placed a piece of vinyl over the padding. Then I tucked the ends in with a screwdriver. Overall it was fairly easy.
I just recovered the entire panel in black vinyl. I then remounted the door trim,armrest and cupholder for an almost OE look. I too wanted to get rid of the door carpet and this did the trick. It does look plain but I was going for the subtle appearance. I may do something different and more 4th gen looking later to go with the '01 RA ebony leather seats I installed over the weekend.
1 Post
Car: 91 RS
Axle/Gears: 10 bolt
I was also planning on doing black vinyl doorpanels with some custom popup work in them to kinda keep them from looking so plain and accenting the popup stuff with the grapite spray. I really like that color thanx for the idea it really helped set off my boring black interior.
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
USA-1, the panels you pictured are actually Trans Am/firebird door panels, not GTA. The GTA panels are much different and require a different bracket to mount the arm rests.
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
gta doorpanels... they sometimes come with triangular pockets in the lower portion
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Car: 1990 Formula
Axle/Gears: 3:73 Posi
Engine: 5.7
if I end up getting a set...I really don't want the map pockets. Is it harder to find them with or without the map pockets?
Car: '91 TA vert
Engine: turboLSx
Originally posted by Dave84Bird
Those were not specific to GTA's they could be ordered in any Firebird, Formula or Trans Am as well. I personally took some out of a factory 87 Formula and a friend had a 86 Firebird S/E with them as well. I also know where there is a 88 base model firebird in a junkyard with a pair.
And yes they require a different bracket that's larger than the regular armrest bracket.
I need some door panel idea's i also wanted GTA's but there hard to find. Wanted 4th gen interior but cant find any oh well . If anyone can get me a pair ill buy some but dont you have to have the riveted bracket off the door also.
1 Post
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Engine: 5.7
I really like the door panels that 90firebird posted. What exactly are those? Has anyone mounted a set like that in a Camaro? Wouldn't I have to hack the drivers side panel up to mount my door lock switches and all the goodes?
There GTA door panels yes you can put them on a camaro think you need the bracket that holds the door handle though. Im sure you could drill new holes in your stock one if not.
Engine: 5.7
these look about like the ones I'm interested in:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Are these panels actually plastic or cardboard? Are they covered in a material or are the plastic? I'm really trying to get out of the fabric look...and more for the plastic/molded look.
Not sure where I would get all of the other stuff though in order to mount them correctly
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The screws on a 'deluxe' panel fire straight (horizontally) at the bracket and has 'plug' to hide them in the side of the armrest.
The camaro's screws diagonally up from the underside to the bracket.
Car: 1990 Formula
The ones i had were fiberglass. all you would have to do to mount them in a Camaro (or firebird not equipped with them) is get the metal brackets for the armrests as well.
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
i hate our doorpanels.. i just dont think their worth it at all.. i go to close the door with that big azz handle thing.. it feels like im closing a door thats been welded at the hinges.. all heavy and stuff.. just hate them but id go all 4th gen no matter what the cond of the 3rd gen stuff
Car: 87 gta 89 ta
Engine: 5.0 5.7
Transmission: 700r4 x2
you can get nice plain regular pontiac door panels with no pockets they would look nice, i changed from a grey to black int in my iroc , but i couldn;t find door panels except manual window ons so i cut a small piece of carpet out of the floor under the back seat to fill in the hole where the crank was, turned out great i think
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Originally posted by 84customZ28
here is a pretty nice set that IrocZDave Has...
Engine: 5.7
Looks great, keep in mind you will have to do something else with your power mirror switch.
I'm just kind of throwing some idea's up in the air right now...but these GTA door panels look pretty good...I'm looking for that more "molded" look...instead of a piece of cardboard with fabric & rubber on it. Could I just a portion of the GTA door panel out and mount power mirror switch?
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
I say go with the gta panels if anything! I have them in my gta and love them. Would love to put a black set in my Z!
Car: '91 TA vert
Engine: turboLSx
you read my mind
you read my mind
Engine: 5.7
You're mirror switch isn't in the center console?
Engine: 5.7L TPI
Axle/Gears: 3.42:1
nope, just the mirror switches and hatch release..not the mirrors
Anyways, I am fairly shy about cutting up parts, were you planning on putting it back on the door or somewhere else? Moving it should not be too bad as you would have to pull the mirror harness back through the door and dash. It's a seperate harness, but I can't remember of hand how much lenth there is between the driver's mirror connection and the switch connection. You may have to lenthen a few wires...
Car: '91 TA vert
Engine: turboLSx
1 Post
has a place it mounts to that is not on the flat door panels unless they were equipt with the same piece.
In the below pic I think it is the one behind the door handle. I will have to take some more pics of joes doors. He has both styles. I will have to compare and take pics of both for you guys!
Above pics are on this page...Cardoamin does not hot link well all the time!Cardomain page link
1 Post
1 Post
I have since done away with it in my door panel swap!
#43
1 Post
Yes, my deluxe package...I had manuel windows, but no map pockets... The hole needed for the window crank is down where the map pocket is...
Check my stereo site...there are pics on my speakers pageStereo site
#44
1 Post
#45
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
i have these in my car and am thinking about keeping them instead of swapping in the 4th gens.... and just having these dyed and recovered....... they flow pretty well.... and dont have 2 change anything ....... ....... i will have to snap a pic of them with the door shut so u can see the flowish lines lol
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
