What do you do with your backseats?
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I keep my backpack back there. But back in the day they had a really good purpose when i was in HS. Took 6 girls i believe to practice all of them were in the back seat me and my friend were up front. The goold ol days. Also made a good seat for dates as well. :lala: :lala:
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
Take em out, you'll get a few more cubic feet of cargo space, thats what I did. Get two pieces of carpet to cover the mounting tabs holes and you're set.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Depending how ambitious your are in you interior quest, when you buy a new carpet kit YOU have to cut in all the bolt holes and accessory stuff. I originally wanted to keep the back seat, but I could'nt get my car into the chasis shop soon enough to have the rear seat bars bent to hug the ceiling/hatch to go over the seats, so I took them out. The new carpet kit I installed completely covers up that area so no metal shows anywhere.
I am taking mine out. As you some others said. serves no purpose (except for the guy who had 6 girls back there. :hail: :hail: ). and is extra weight.
And if you remove it, legally it become cargo area which means you can relocate the battery back there and still be good for racing.
Car: 1988 Camaro
VILeninDM... It's not that simple when it comes to batteries.
To be legal with NHRA, IHRA, NMCA, ect ect you will have to use a fully sealed and vented out of the car poly box (moroso blue box)
3/8" hold down bolts, no J bolts, tops must be welded together, and the bolts must go through the frame, not the floor pan
In unibody cars you have to weld 1/4" thick stock to the frame rails, then bolt your battery hold downs through the stock.
Also if battery is anywhere other than stock placement you have to have a rear mounted battery cut off switch that can kill all voltage flow and kill engine
Hey night rider, thanks for the info. I was planning to do something like this, but right now don't even have an engine, so I didn't look into details yet. I just remembered other threads on here where people done similar things to remove some of the weight from the front end.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I've thought about some kind of modification back there...but I really haven't seen any cool idea's. So..I'll just keep'em back there for now
did a search on this idea... found this thread
https://www.thirdgen.org/techbb2/sho...ht=tail+lights
seems that this is one of those topics that may be a bit to far outside the norm for some to manage without mocking it.....
How about doing something like this?
There's a guy who sells these on eBay.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33701
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
Little channel it is to Palos the custom Dole speaker boxes
I got rid of the seats the first week I had the car and built a custom speaker box with two 10 in. J L. subs and I have two 2 channel amps built on top of box. The speakers are facing towards the back of the front seats. I also have a box built on Top of that box that holds to 12 in. JL audios faceing trods the back window I have a custom amp rack built with the tee top bags would be to see amp rack cases a 2 channel amp and a four channel amp. And finally I have an another box in the back back that holds to more JL audios. I guess some what of a fanatic when it comes stereo systems. The four channel amp is for the custom door speaker boxes. The biggest downfall about my system is that my 4, 12 in. JL's are muffled by my custom notch back. But I think the sacrifices worth it for the look of the notch.
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
wow, those things are pretty slick..
this is pretty much how my rear seat area is.. don't mind the mismatched interior, I'm in the middle of a med. beechwood->black swap. I ditched the seatback bc I felt these pillows offer a couple of extra inches of leg room (in our case, thats a significant improvement).
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
Mine are gone, in their place are a constant cycle of 2 rims with used tires and a floorjack. bahahahah
speaking of how is the green machine holding up? haven't heard any details in awhile..
Car: too many ...
Hehe the one in my sig current has nothing!! hahah no back seats, no front seats, total ghetto style hahaha. The green machine is holding up, supprisingly it didnt blow up yet. I was out drifting with it this past weekend, got some alright video. I'm getting ready to do suspension/steering next, gonna do it all at one time.
Car: 1986 Trans Am
Engine: 6.0L LQ4
I keep mine folded down. Just makes an extended trunk but if you have a date (FAST RS) with or your taking SIX GIRLS to practice. Then you can let them up!:hail: :hail:
1 Post
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Got all mine. No one ever rides back there...torture...got tools and my bag for work! Actually when i was fixing up the interior I left the backseats out and ended up sitting back there in the holes while working on the speakers...they are way more comfy then the backseats. Alot more room too. If I get a toy 3rd gen that I don't plan to show I might just pad the area under the carpet, but leave the seats out. Problem is moer carpet kits are 2 pieces and the front and rear piece come together there!
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
I still have mine. Allthough, I remember a story about a guy who removed the concaved seat portion(where your butt sits). He boxed the area in sheet metal. His goal was to make a spot under the car for dual mufflers. Any verification of this being done before??
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Mine are still in. I drive alot with my friends so it gets used offten. The back seat is really not all that bad, my best friend Jeff is 6'3" and sits back there with no problem.
Kevin
Kevin
1 Post
You or the passenger mashed against the dasH? Or does he use the backseats as a long couch?
Car: 85 Camaro Z-28
Engine: v8 305 4bbl carb
Transmission: t-5
mine are all out including the front ones and the carpet and the dash and steering wheel hell I have nothing inside other that the shifter, and emergency brake.
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Does anyone have pics of those covers from ebay? I'm curious to see what it looks like from farther away or from the rear. I move alot of guitar equipment and now maybe I can finally fit more than 2 guitars in there.
Car: '85 Z28
Car: 1986 Trans Am
Engine: 6.0L LQ4
Kevin
Kevin
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
Im looking to take them out and do a fiberglass mold so it looks natural with the car (not as if seats or something should have been there)....Im currently going over prices for the job and ttl weight. Ill mount some speakers and amps in it as well
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
well if ur all about performance and dont want nothin to affect ur time.. then i would say get that really really thing stuff and make a light box sumtin not for subs.. i dunno
#42
yea if you were to use plywood for the box like most are made from, it'll be really heavy.,...thats why I was thinkin about going with fiberglass...Crazy3rdgen thats exactly what I want to do, except the two subs in your pic look a lil cheap to me
#43
Car: 1990 RS coupe
Engine: TBI 305.
#44
Engine: L98, Hemi 6.2
#46
Originally posted by mw66nova
ok, the big question in my head right now about those boxes is: do they wiegh less then the seats did? this is the only reason i would consider buying those boxes.
#47
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
i took mine out
gives you alot more storage room and stuff
and like redraif said, it is actually moe comfortable to ride back there with them out, more room and a better position
my best friend that almost always gets stuck back there cause my girl is in the pass seat wont let me put them back in , and ive ridden back there to, it really is better
#48
Originally posted by crazy3rdgen
what the Elemental designs and my rockford fosgate 1001 bd ?
lol no we were talkin about the pic that you drew up....although I might wanna buy that 'amp' brand amp so pm me with the details
#50
Car: 91 Red Sled
You could do what I did and install your stereo amps into the back seat. To show off the amps, fold down the seat, same to tune the gains and para-eq (if you've got one). Fold it back up and everything is stealthy clean. Never had a problem with overheating but I don't use the stereo on high nore do I believe in cheap amps. My moto; Do it yourself, do it once, do it right.
