Weatherstrip repair?
Car: 89 Formula
Engine: 350ci, tbi
The weatherstripping around my driver side window is fine except for one little spot at the top left and its leaking like crazy. DOes anyone have a way to fix it without replacing the whole thing. I'm thinking some kind of flexible glue ?
any thoughts?
any thoughts?
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
you could jus use some black weather stripping adhesive
srr delayed response but yea what he said
Originally posted by CaysE
3M Strip Caulk... comes in a blue box, available at CarQuest.
Just out of my own experience, weatherstripping adhesive doesn't work too well as a filler... it works best when sealed between two surfaces (weatherstrip and body of car, for example). The strip caulk is made to bridge gaps and fill holes.
It also works great to keep those door jamb vents from rattling.
Car: 1894 Camaro Berlinetta 305 auto
Engine: 305 LG4
Transmission: TH 700 R4
caulk
really ive done this with my dad an most of our cars and if you just tape off the window and put some caulk down(any exterior caulk will most likley due) and spread it along the crack ed weatherstripping and basicly rebuild the weatherstriping with the caulk.
Car: 89 Formula
Engine: 350ci, tbi
Thanks guys, I will pick up some of that tonight. I just hope i can get it on there without it looking ghetto.
1Aauto
Sponsored Vendors
10-19-2016 08:50 AM
1Aauto
Sponsored Vendors
10-13-2015 03:06 PM
