GM bright red or Torch red???? im confused
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Hey guys i gotta get paint for my gf 91 firebird becuz i gotta paint the front bumper and lower fender gfx. im not sure what the color is exzactly. i was on PPG website and the 2 reds for 91 are pretty close. now her car is stock but has been repainted the factory color. im sure she doesnt have her RPO sticker anymore but i can serch.
anyway is there a huge differnce in person in the color? i just dont wanna get the wrong one. since its about $186 for half gallon.
thanx guys
thanx guys
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1992 B4C
Engine: 4-bolt 350 219cam Superram
Yes, there is a big difference. I know torch red has an orange hue and is the color found on some of the newer C5 corvettes, bright red is a rich red found on other Chevy’s including Irocs. My brother has a 91 Camaro which originally came in torch red but chose to repaint it bright red (like his old 89 Iroc) and you can see a big difference when we replaced his carpet.
Your best bet is to go a paint shop or paint store and ask them for a color paint chip chart for 1991. You will easily be able to tell one from the other. Hope this helps..
Car: 05' GTO
Engine: 6.0L
Transmission: A4
okay thanx. becuz my brother has a 91 z28 thats gm bright red and his car and my gf car is pretty much the same color. i think ill have to check her center consoule and little compartment in the back for the rpo sticker
Car: 05' GTO
Engine: 6.0L
Transmission: A4
okay kool thanx guys. how much paint do u think id need to spray the front bumper and lower fender gfx pieces. its $186 for half a gallon but i dont think ill need even that much but wouldnt hurt to have extra
Car: Take
Engine: Your
Transmission: Pick
Probably get away with a pint. Remember, most basecoats are mixed 1:1 so you'll have 2 pints of sprayable material. You don't put basecoats on thick, you spray just enough to acheive "hiding". This is usually achieved in two coats.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
so basiclly i wantto just get to hide the primer? im still new to painting and never was taught anything, just goin by what im thinkin is right and what ive seen done. well i think with some of the extra paint i got in my garage ill start sprayin some test panels and figure out how i should set the gun and mixtures.
hey GMtech my bigest question is about readin the mixing cups. i got the 12 piece kit from eastwood and dont really have the big of clue. most of the time i use the biggest which i guess is a gallon and i just use the 1:1 spot on it mixing the paint and reducer. ill take a few picks of the cups i use or look on eastwood so ya know the ones im talkin about.
1 Post
Car: 3
Engine: inboard
Transmission: underfloor
Tim,
The amount and type of reducer or activator to paint will depend ENTIRELY on the type of paint you buy. Are you using a base/clear type paint, or a single stage? Use what ever is reccomended by PPG for the type of paint you buy.
As far as getting an EXACT match- because the car may have faded over the years, the best route to getting the match is NOT to go by a factory "chip", but to have the paint store do what my local PPG dealer calls a "Chromavision" scan, basically, they have this scanner that looks like a stud sensor and it "reads" the paint, and tells them what to mix to get the hue correct.
A good paint shop will tell you exactly what products you need to go with the paint you buy. If you are painting ground effects and urethane parts you will be well advised to use an "adhesion promoter" type product in the preparation stages, and probably a "flex addative" in the actual paint.
I have found that reds take a little more to hide the primer than other colors I have sprayed. Your results may vary.
Eric
Eric
Car: 05' GTO
Engine: 6.0L
Transmission: A4
the type of paint im buyin is ppg's DBU line. i already have the reducer from doin my friend hood. all i need to do is buy the paint. so i guess ill end up just needing a quart just incase.
the paint on the car was redone about 2-3 yrs ago and hasnt faded, so i dont think it should be hard to perfectly match it. plus she just wants it took look nice till she can aford a really good paint job.
also do u think the adhestion permotor is needed since the replacement nose we got was new but painted black, but its all sanded down ready for final sandin and priming and paint.
1 Post
Car: 3
Engine: inboard
A quart should be more than enough.
AS far as adhesion promoter etc I would ask the paint store, tell them what you are doing and ask what they reccomend.
AS far as a color match the only concern of mine that would cause me to have them scan the actual color is the fact the car was repainted and you can't be sure the brand of red used by the last painter is the same as the red you are using.
In other words, PPG's "Bright red" may not be an exact match to Du Pont or Maaco's "Bright red"
I would test spray a small part, let it dry, and compare it to the rest of the car if you are not sure- that way if you need to have the store tint the paint slightly one way or the other it's no big deal and you don't have to re shoot an entire panel.
Either way, I'm sure it will turn out decent- you never learn if you don't try. Did you paint the black car yourself? It looks great!
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yeah i guess ill get a pint and see how things go. also i didnt paint my car i had a friend do (hes like 50) it and it turned out decent. could have turned out better with the paint booths temp. controls were working and if we hadtime to wetsand the car.
next year or next winter i might get it totally repaint, im goin toi start body work again on this car. its not that bad, did it once and ill do it again.
Dragonsys
09-25-2015 03:51 PM
