Remodel Door Panels...
In an effort to be really creative I have decided to redo my door panels. I have several questions first though:
1. What material can be used to replace the panel backing? Does anyone sell this stuff?
2. What kind of materials can I use to build shapes and designs?
3. How can I attach the designs to the backing?
4. Where can I find fabrics or materials to cover the panel?
There are probably other question, but I can't think of any now.
Jim
Jim
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
home depo my man, and some 1/4 inch foam, and some fabric, if you wanna get really crazy, fiberglass pannels, but thats a lot of skil involved.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1990 Formula
Axle/Gears: 3:73 Posi
I used tweed to recover my original door panels, the factory had 3 different materials and 3 different shades of grey. i wanted something clean simple and one color. then i put the factory piece of metal trim back on to give it a factory look.
But if you wanted shapes, just cut the shapes out of foam, and them glue the new fabric over the foam.
Good information so far, thanks. But what about the door panel backing, the multi layer press board sort of stuff, what can I use to replace this???
Does any manufacturer supply this?
Jim
Jim
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Looks good but a little to plain for me. It would be cool if it was raised in some spots. Otherwise good work.
Car: 87 IROC Z28
pressed board is good nuff
1/8th inch think
make sure you seal it fromt eh back and ptu the plastic backing back on the door
1/8th inch think
