4th gen dash. dimmer Q ???
Old 10-16-2004 | 02:56 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
been searching and taking notes. i have no use for the dimmer.
can i just hook up the headlight switch and be done with it, or do i have to go threw the dimmer as well?
thanks
Old 10-16-2004 | 03:35 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
having the headlights working properly shouldn't be any big deal w/o using the dimmer as the two use seperate wiring, which if i recall correctly, doesn't rely on any other componet of the headlight setup, so. yOu should be good to go.
Ghettobird52
07-06-2024 12:18 AM
Warlocksirix
09-03-2015 01:26 PM
cam-mike
08-24-2015 08:23 AM
Quick Reply: 4th gen dash. dimmer Q ???
