How to remove rocker planel GFX
Car: 89 Trans am
Engine: TBI 350 HO Vortec heads
I just took one off the passenger side at the junkyard and i really didnt take it off correctly, i dont think i hurt the gfx but it just didnt feel right.
anyways on the circles blue spots is where i had trouble there was like werid (idk how to describe them) but it came off funny, if anyone knows the correct way to install and uninstall these GFX please help me out.
Not positive, but I heard somewhere that to remove the back portion, you need to go thru the rear speaker opening. Never tried it and never saw it done, but I thought I heard it here before.
Car: 89 GTA (88 Firebird V6 to V8 conversion RIP)
Transmission: 5 spd
Ok, good... I'm not crazy... I thought I read/heard that somewhere too... I was going to post that answer earlier but didn't want to post it if it wasn't true....
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
On my camaro you have to take out the rear 6x9s and reach all the way down and theres one 11mm (i think thats the size) speednut. On my old 82 t/a it was the same thing with the rear "spat" gfx
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
I have an 88 camaro and when i tried taking off my GFX's the front part came right out because the front fender was so badly rusted, but the back part woudnt budge. Anyone know if its possible to mount 91-92 GFX's if the tabs are missing?:lala:
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Accually I did this today. Remoce the plastic panel under the wheel well in the front and remove the back bolts from there then push the GFX's back. The back slide off meaning no need to remove plastic intior inside.
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
Originally posted by Dante93GTZ
You are really doing it the hard way.
I did mine by removing the side plastic panel and then there's an access square hole covered by a rubber patch. Remove the patch and there's your screws:
jeff
New2Chevy
09-28-2015 12:35 AM
