'85 dash removal.......
Old 09-27-2004 | 08:06 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
does anyone have instruction or diagrams on how to remove your entire dash board? no help from my chiltons manual. my dash needs replaced bad! the whole piece (already got the top off) thanks.....
Old 09-27-2004 | 09:28 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
did it to my 85....essentially, just keep removing stuff. get the hush panels from underneither pulled off, remove bolts to frame on the corners, remove bolts to firewall on the top (under the old pad). There will be bolts holding the rest of the instrument cluster on that you can also remove, then remove the cluster, there are two bolts that go into ur steering column, those'll have to come out. plus numerous other bolts that are slipping my mind right now. It really isn't difficult, on mine, the hardest thing to do was to remove the stupid speedocable, its only one clip, and you might have to pull hard, cause this might be the first time it's going to come out in 19 years.
Old 09-27-2004 | 09:33 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
yeah, that damn speedo clip was holding everything up! and when i finally get bk there, it was one silly screw holding it on.... so how do i get everything bk on when i get my new pieces? is it easy? how lond did it take u?
Old 09-27-2004 | 09:34 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
can u fit 4th gen dash's and stuff in there? i know i can use the seats.... thanks :hail:
Old 09-27-2004 | 09:51 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
if you do a there have been quite a few people put fourth gen dashes in these cars and they look awsome ....
Old 09-27-2004 | 10:12 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
yeah, i'll have to do a search and c what they look like....
Old 09-27-2004 | 10:37 AM
THEGENERAL's Avatar
heres a good thread on this for you ...if you search for 4thgen dash in 3rdgen it will bring up alot of threads for you ...
heres one
https://www.thirdgen.org/techbb2/sho...ash+in+3rd+gen
and heres a pic of one in
Old 09-27-2004 | 10:43 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
wow!!!!!!!!! how in the hell did they do that!!!!!!!!! thats pretty slick, did it match right up? bolts and screw? or a little modification? :hail:
Old 09-27-2004 | 11:35 AM
85f-bird's Avatar
Engine: 2.8L, LS1
don't know how hard it is to get all the stuff back in place, as i was doing a 4th gen swap. The 4th gen stuff fits, just needs some tweaking, but it'll be some more work if you're trying to make it look factory. And that, will require more than just a "little" modification, it'll be somewhat extensive.
hectre13
Car Audio
26
03-03-2022 06:38 PM
86IROC112
11-07-2015 07:50 AM
Fanatic1074
10-02-2015 04:47 PM
lewandom
10-01-2015 09:15 AM
Eric-86sc
09-28-2015 12:37 PM
Quick Reply: '85 dash removal.......
