Rubbing Alchohol discolors plastic
Old 09-27-2004 | 05:10 AM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
While re-installed an emblem I popped off on the dash of the interior. I used Rubbing Alcohol (as instructed by body shop, and online) to clean the surface. I then put the cotton ***** that I soaked with rubbing alcohol on the center console Plastic center where under the "Left Window, Rear Hatch, Right Window" automatic buttons are.
Turns out a couple drops of the rubbing alcohol that touched this center console plastic area discolored it to a light black. So now there is 2 little drops of light black (light grey more like it) circles..
Is there any way to return the black color of the black plastic center or would I just need to buy a new upper center console which sells for around $89us?
Old 09-27-2004 | 05:14 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
just remove the piece and respray it with a light coat of interior black paint, allow it to air dry, re-install it and you'll never know anything ever happened to it...no need to spend 90+ dollars to replace a plastic piece that merely faded....
Josh
MrPackstin
10-25-2017 09:09 PM
Twin_Turbo
03-14-2016 11:10 PM
Night rider327
09-25-2015 05:19 AM
Saxondale
09-15-2015 07:42 PM
gteatr6
Interior Parts Wanted
09-10-2015 10:55 PM
Quick Reply: Rubbing Alchohol discolors plastic
