Fiberglass frontend?
Car: 89 IROC-Z
Engine: L98 - Stock
Has anyone here used a fiberglass setup? On the link below, there's a fiberglass front (both fenders and front clip). $695. Being all one piece interests me in weight savings...but if I crack up the left side again...I'm out $695.
http://www.showcars-bodyparts.com/8292cam.html
Also, here's a picture from their site - Photoshoped so you can actually see it.
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
only thing is that it appears to be for race car applications, not sure there is room behind it to fit things like bumper bar, headlight brackets and other such things
Car: 1984 z28 ?iroc z? camaro
Transmission: auto
they are cheaper on www.classicindustries.com
1 Post
Car: 92 Z28
Engine: Boosted LSX
The galls front clips are 4inches longer then stock. Ya it could be trimes but its not really worht the fab work to put the lights in etc.
http://www.cecoatings.com/images/oth...S/DSCF0010.JPG
Car: 89 IROC-Z
Engine: L98 - Stock
Thanks guys, it does appear to be meant for a race tubular chassis trying to look like a Camaro, ranther than a stock Camaro trying to save a few pounds....like me. I'll just go GM steel and plastic to fix my damage.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
what thats for is like you said.. when you put tubes inplace of the inner fenders for the struts and you want to remove the whole nose..... i know a few racecars with that nose... (most are ******* engineered POSs)
Car: 94 Firebird
Engine: 3.4L
Transmission: t5
back in the late 70's up till now... the sheet metal used to make the bodies were so thin that for mere weight reduction, fiberglass applications are useless and expensive... the only thing worth your time might be the hood, since fiberglass is structurally more hard than sheet metal, you gonna save the weight of the hood frame... but if you do it for weight reduction and not for aftermarket look... really it isn't worth paying 500 bucks... shave some of that extra weight inside of the car... and find a notchback instead of the huge glass behind our cars...
Car: 91 pro street camaro
Engine: F1r procharged stroker
Transmission: turbo 400 w/gearvendor OD
Axle/Gears: moser 9" 3.89 35 spline axles
notch back
trying to save weight on the wrong end of the car!!
Car: 1991 Z28
Transmission: 4L60 automatic
Re: notch back
Car: 91 Z28
Transmission: 4l60e
he means that there is tons more weight that you can shave off in the rear, as apposed to the front end where not much can be done to shed weight
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ahhh but you don't want to lose weight in the rear.
Not until you have the ratio of front n rear figure out.
You can actual get the car to handle better by adding weight in the right spots.
Having the car balanced weight wise is a better mod then just pulling part n losing weight anywhere. But losing weight in the front is the best place to lose it. In general.
Car: 1991 Z28
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
It's kind of a generic term i've heard throw around at the track, but they say if you take 30lbs off the nose and put it in the rear it's like adding 60 lbs to the rear with the weight transfer action taking place.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yep, speaker and amps in the truck can actually help if it provides you with more traction then the other guy.
Id probably just get a glass hood n fenders. Keep the rubber nose so you can bump stuff. I assume its gonna be a driver also.
Car: transam, el camino
Engine: 415
Fiberglass fenders won't help you out that much, I'd get a hood and a front bumper cover in fiberglass if your trying to lose weight. An aluminum bumper bar from an 82-84? 4cylinder car will also drop weight off the front. Alum. heads and a tubular kmember/arms Alum. waterpump and S10 manual steering box. lighter wheels, fiberglass dash.. depends if it's a weekend strip car or a driver and how much you wanna spend.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The flames oh the flames..........
A SBB is 100lbs less then a SBC stock...............
Parts are not a porblem anymore.
PAE builds them for $6000 with stock block, heads, crank
with over 500hp
http://www.paeenterprises.com/paeframe.html
"One of the Most Underestimated Engines
The 350 Buick engine is probably one of the most underestimated engines, even by Buick people. These engines are well designed, they are built strong, not overbuilt. They are also the lightest of the "Small Block" engines, weighing 100lbs. less than a SBC. These engine have a super long stroke, as far as I can find, its the longest stroke of all the small blocks, by a good margin too. The bore size does suffer a little bit from this but torque makes horsepower and long strokes make torque. A chevy or ford has to wind up to a much higher rpm to come even remotely close to the torque that the Buick 350 puts out at 3200 rpm.
with over 500hp
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
