T/A taillights delaminating
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
First off I did a search for this and didn't come up with anything. I'm wondering if anyone has experienced the grid on the Trans Am taillights coming off the back, and if it is fixable. I haven't yanked my lights yet, so I'll probably do that this weekend. Has anyone else experienced this happening? If so, what did you do to fix it?
Thanks,
super_kev
Thanks,
super_kev
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
does it look like the grid part is bubbling or are the black pieces simply falling off? either way, your lights are going downhill... I advise you buy a new set or try out that nightshades spray on tint... i found a new pair at the junkyard when i realized my old ones were crap... here's a pic just for ***** and giggles...
Car: '85 TA
Yes, the grid part is bubbling. I was wondering if there was a way to take apart the lights and reglue the grid or something.
1 Post
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Joe had a set that was delaminating on his car. We found a good set at a junkyard and swapped them out. I worked on the delaminated set. Could not get them to look good again. Would not glue back. So I busted out the plastic grid and polished the lens and got this result...
More pics here
More pics here
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
[i]So I busted out the plastic grid and polished the lens and got this result...[/URL] [/B]
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
wow, good job on that one redraif.. it seems like its too tedious to me, plus you'll end up with remnants of the grid...
Car: 85 Trans Am
Engine: 305 Carb
redraif
How did you get the outer lens cover off? I have this problem with my lights, and it looks like the outer lens cover is glued on. Did not try to get it off for fear of breaking it.
1 Post
Originally posted by Goumba T
They look weird, but not all that bad. Maybe if you could sand the backside so there was no impression of the grid left they'd look a lot better.
Originally posted by wilyk9
redraif
redraif
Mine grid style had no glue. Just pins at the top I had to pull up and out, like the ones in our fender wells holding in the plastic liner. Once they were out you look on the bottom. There are these metal clips. You just pop them off. The the lense will separate simple as pie.
To my knowledge, this design is only on the grid style and older finned style tailights. The stocker lights are glued adn are a PITA. The other styles I have never separated.
1 Post
1 Post
Car: 85 Trans Am
Engine: 305 Carb
Originally posted by redraif
What style lense do you have?
2012sergen11
10-13-2015 07:38 PM
