Suck it in!
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
Suck it in!
I bought my '82 Trans Am from a professional racer back around graduation. She sat for two years being ignored. My dad and I are restoring her. The passenger side back seat, its seat belt is locked as if the brakes are applied. Only the smallest of passengers can use it.
Any help will be greatly appreciated, thanks.
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
time for a new replacemnt there is no way to fix em since your life depends on them chcke hawks sponsored link above he has all colors used and maybe new too
jeff
jeff
Engine: 5.0L 305 H
thanks
thanks, i was afraid that that would be the case. i was hoping that the seat belt locking mechanism needed greased.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Don't know if older (or other) work the same but, in my '87, the rear rear pass seatbelts are a 1-pull for the correct length then 'ratchet' tighter as they retract.
Untill the seatbeat fully recoils/retracts, you cannot pull it out further again.
Both sides work like this so, I'm somewhat positive they didn't fail at the same time.
Engine: 5.0L 305 H
Originally posted by 82FirebirdTA
What color is it? I might have 1 you can have....
she's a 1982 Trams Am
Car: 1989 Toyota Supra Turbo
Engine: 7M-GTE
Transmission: R154
Axle/Gears: 3.91 LSD
![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
We know that man..
what color is your seat belt?
Car: 1986 Firebird
Engine: 2.8 V6
I had that happen once to the rear seatbelt on the driver's side. Someone sat back there, and a couple days later I noticed it was stuck. So I removed the seat... there was a piece of plastic on the bottom of the retractor that worked it's way loose (it was like a clip or something) and was jamming the mechanism. All I had to do was move that piece of plastic and it was good again. Maybe it's the same easy fix for your rear belt? Remove that side's seat bottom - use a 13mm socket on the single bolt at the middle of the seat's bottom, about an inch above the floor. When the bolt's out, just lift the seat bottom up and pull towards ya (it's velcro'd to the rear carpet). Then have a look at the bottom of the stuck retractor. I didn't have to unbolt the retractor from the car, I was able to see the problem easily.
I'd give more detailed info then "a piece of plastic jammed it" but that was back in '95!
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Pac J
05-17-2020 10:44 AM
tyeo098
11-30-2015 06:27 PM
3.8TransAM
10-01-2015 07:47 PM
