What's the racket!?!
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
I bought my '82 Trans Am from a professional racer back around graduation. She sat for two years being ignored. My dad and I are restoring her. There's an annoying deep vibration in the back end, maybe extuast. I know it's not the tire spare.
Any help will be greatly appreciated, thanks.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
you start every post with this line. "I bought my '82 Trans Am from a professional racer back around graduation. She sat for two years being ignored. My dad and I are restoring her."
then you ask a question.
STOP IT!
you say its got an lt1 in it you think? why dont u check, the intake alone would give a pretty good hint.
STOP IT!
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
STOP IT!
STOP IT!
lt1 most likely not, its pretty easy to tell
Car: 1986 Trans Am
Engine: V8 305 LB9 5.0 T.P.I
Transmission: THM 700 R4 Auto
I had a bad vibration in the back of my bird. It was the heat shield for the gas tank. its between the muffler and gas tank (duh). Mine was missing a few screws so it was hangin low> give that a try....
-adam
-adam
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
you say its got an lt1 in it you think? why dont u check, the intake alone would give a pretty good hint. [/B]
The original high-performance LT1 engine, a 350-cu.-in. "Small Block," was introduced in 1970. It generated 370 horsepower. That year, the "Big Block" displacement was increased to 454 cu. in., and was rated at 390 horsepower in the LS5 version.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Things to check
U-joints
Tranny mount
Loose jack/spare tire
Loose rear suspension parts or hitting bump stops
U-joints
Tranny mount
infinite_one
03-27-2014 04:55 PM
