GM replacement parts paint/prep work???
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Hey guys im goin to be gettin an entire set of 91-92 z28 gfx and the nose, lower chin spoiler where replaced with new factory pieces from GM and well i guess the body shop that painted it all didnt do a good job and its flaking off in the head light pockets and few other spots. im not that concerned since it all has to be stripped.
but what has to be done with the new parts in order for the paintot stick good? like would a epoxy primer be good or would i have to put a sealer on it and then epoxy primer and this would be after sandin everypart with 180 grit paper.
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
use a good self etching primer such as etchlock made by sherwin willams over the bare plastic thast should create all the adhesion you need
Car: Take
Engine: Your
Transmission: Pick
Once down to bare plastic, the FIRST step is to use Plastic Adhesion Promoter. Also note that some plastics will asorb solvents, so do not degrease with solvent based cleaner. Use a water based/alcohol cleaner instead.
Then follow up with the epoxy primer, but to remain flexible, you MUST follow the tech sheets!
Car: 05' GTO
Engine: 6.0L
Transmission: A4
All the stuff i have for paintin and priming are PPG supplies. i think ill have to take a look in my PPG book to see what adhesion promotors they suggests in there.
i dont think id use anyting from sherwin williams from the stories ive heard about there stuff and how there just like another macco.
but i do have a good self etching primer from PPG that worked good so far. but ill still end up gettin a good epoxy primer probably black so when and if my gfx get scratched it wont be that noticeable.
Car: 87 Formula
Engine: 350 tpi
ive actually used sherwinn willams paint on 2 cars that ive painted and i couldent be more pleased with it but i mainly use ppg i jus couldent think of the name of the self etching primer from ppg ??etch-it?? i think maybe its called
Car: 88 IROC-Z
Engine: 5.7 TPI 350
Hey GM Tech, have you tried PPG's new line of base coat "Envirobase" yet? I too am a PPG certified paint tech and the shop that I work at uses Envirobase. And let me tell ya it was one h**l of a change going from DBC to Envirobase. But for the most part I think I like Envriobase better than DBC, it seems faster.
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
Terrell351
06-13-2021 01:13 PM
