omg! pics of a 6 inch cowl hood
Car: sc
Engine: 383carbed
Transmission: th400
Axle/Gears: 4.11 12 bolt
Car: sc
Engine: 383carbed
Transmission: th400
1 Post
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
that has to be bigger than 6". mine measures, because i checked, 6" and it goes up maybe a 1/3 of the windsheild. the view is not very bad at all.(on mine)
Car: sc
Engine: 383carbed
Transmission: th400
Originally posted by Aredross
Thats not your daily driver is it?
1 Post
Car: 1986 camaro
Engine: 383 sbc
what is the top end of your motor like? i.e. intake carb/fuel injection, air cleaner? etc.
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
Originally posted by rentacopper9mm
naw,this guy is a member on the reader rides. i was told by my mec that i needed a 6 inch to clear for my 415 c.i. that will be dropped in soon
you sure you mec knows what hes talking bout? cus i'd really like to know what kinda setup needs a 6" cowl
1 Post
Car: 1986 camaro
Engine: 383 sbc
mine as it is with a drop base 3" element sits approximately 41/2" above my hood which is why i got the cowl. once i get my 4" filter on there and my nitrous plate system i will be right near the top of the cowl.
Car: sc
Engine: 383carbed
Transmission: th400
Originally posted by kretos
not trying to come across as an *** or anyting, but there are guys on this site with 454 and 502's that are supercharged and carbed and a 4 " usually does it just fine.
Car: 86 "Ram Air" IROC
Engine: 305 5.Slow
Originally posted by Abubaca
There are some things that just shouldn't be done. Personally I think 4" is too much, but understand sometimes it's needed.
I just don't want to go fast THAT baddly.
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
going to need at least 2 inches of clearence,naturally asp. 415 carb pumping out 625-650 h.p. on race fuel .
Car: sc
Engine: 383carbed
Transmission: th400
i will reserve my comments after the engine is installed and when i return from the track,approximatly a month from now.
I have no doubt it'll be fast, and that's cool!!!
...I'm just speaking about how it looks. IMHO, looks and performance go hand in hand.
I'd NEVER have anything bigger than a 2" cowl. I think it looks ghetto. I wouldn't run an engine that wouldn't fit under a 2". Performance would be sacraficed.
...on the other hand, I love the look of the long tube runners, but I may eventually change intakes for the sake of higher air flow. In this case, looks may be sacraficed.
...but to each his own. But lemme say this: With that hood you better be F A S T. I mean REAL FAST!!!
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
im w/ the rest of the group on how it looks. definatley not impressed. My background deals for the most part with appearance, although i do know and understand performance, however as stated above, they should go hand in hand. Sacrificing one for the other is ghetto/white trash (all the same) and no matter what, that's what people will think.
Same time, i'm not one who believes that 3rd gen's make good drag cars. Not on the basis that they can't be made to go HELLUVA fast in a straight line (cause they can, pretty easily actually) but they simply don't look good as drag cars. There are few cars fromthe 1960's that can't be transformed into a good looking drag car, the 70's can get picky, the 90's have many potential cars, etc etc......1980's only have a specific few, and the f-body isn't one of them. They were Performance cars, not straight line cars, (i.e. you can go fast straight in line, however, you can also slam the brakes, twist the wheel, unlock the brakes, power through, find traction, and go in a different direction....they handle, as f-bodies are supposed to, turning them strictly into drag cars severly limits the vehicles potential from it's original design.
1 Post
Car: '86 Berlinetta
Well I for one would be impressed if I saw that car on the track. I would expect it to have atleast a supercharger or blower under there, and 650HP N/A is nice Dont worry man, if you like it then no one else's opinions should matter.... though you probably shouldnt come on here asking for their opinions if you dont care about em heh.
1 Post
Car: 1986 camaro
Engine: 383 sbc
your telling me because of my intake setup...2" space, holley 750 and a team g intake with the raised plenum means i have to run 9s and that i cant have a 6" cowl... then let me go get an aero scoop and then see how fast you think i should run. i am not one to get angry but this the biggest pathetic argument i have heard here in a while.
Car: 1990 Camaro
Engine: 355ci
And for the record. I wasnt really saying he had bad plans for the motor he wanted to build. Its just that if i had the option of running a high compression motor that makes 600 hp and runs off race fuel or to run a slightly lower compression motor make 550 hp and run on street gas it would be a pretty easy decision.
Car: 1990 Camaro
Engine: 355ci
I think this thread has gotten off to a rough start. It's all good, and to each his own.
What kind of HP predictions do you have for the motor?
1 Post
Car: 1986 camaro
Engine: 383 sbc
with my future nitrous plans roughly 500-550 hp plus i might be getting different heads in another year when funds go up.
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
Blah, big cowls rule.. he he.. Well only run them if you need them. IN my case, eh, i need it..... Not much ways to get around it.. i may have been able to clear a 4 inch, but i highly doubt it....
Here is why i need it...
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
If you've got a roots-type supercharger or tunnel ram, then I can see the large 6" cowl hood.
Basically, it looks pretty silly unless mechanically needed for clearance. (IMO)
let u know as soon as my mec gets it back from engine shop.
#42
1 Post
Car: Trans Am
Engine: chevy 350
Originally posted by bjm323
Tell me this isn't a badass ride.
Why do all pro stock 3rd gen camaros have to be a fruity color?
#43
1 Post
Car: 92 Z28
Originally posted by Firebird 383
Yes it is. But it's a full-blown race car running a Pat Musi 632 engine, a jungle-gym rollcage and 34.5x17 funny car slicks. I agree, THAT car needs a 6" cowl hood.
#44
Car: 88 GTA
Engine: 406ci
Transmission: Tremec 3550
There, that is my argument, since I had to spell it out for you, and it is far from pathetic. The only pathetic thing in this thread is your insistance that you need a 6" cowl.
#46
Car: 88 Camaro S/C
Transmission: 700-R4
So is that a 6" cowl or larger? Anyone find out yet?
I really hope that's not a 6". Long story short, I'm getting a Camden Blower and my dad's telling me I'll need 6" clearance. I don't want to look like a freak car though hehe. I will be able to back up the look though hehe, a built 355 pushing 12-16 pounds of boost!! wahoo can't wait!
#47
I can see the getting one to clear a tall carb-tunnel ram setup and having it covered instead of having to use one of those huge odd looking funny car scoops. On a car thats only driven on street it would be silly.
#48
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I would rather try to lower the engine in the doghouse than to put on a cowl hood... If you have that big cowl, then people expect you to be fast... If you look stock then you blow their doors off as you pass them then that is a shocker... I like shock effect I guess...
John
John
#49
1 Post
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Hold on. You are having an engine shop build it, but you don't know what parts they're even using? That's scary. You also said that your mechanic told you that you needed a 6" cowl hood. If you don't know what the top-end parts are, and the mechanic hasn't received it from the engine shop (as stated in your above quote), then how would he know if you need a 6" cowl hood?
#50
