A great idea for the 82-85 bird guys!
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
I had never seen this done before, great idea!
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
i would say definitely the Camaro 145 speedo...pretty spiffy, but i still would rather see a newer Firebird gauge set swapped in because it looks a LOT cleaner and matches the whole Pontiac theme...but this is different, and a lot easier, lol...
Josh
Josh
Car: 84, 86
Engine: 84 w/V-6, 86 w/305 V-8
Transmission: both auto
Well the dude that previously owned mine removed the plastic "lenses" covering the gauges. Now seeing as I am a newbie here, it is one piece all across or are they separate for each cutout? I'm thinking that if I can't find an original ingood condition that I could fabricate my own from pieces out of any flat gauge cover? What do you guys think?
well, IIRC, the lenses are all one big piece...they have special holes to put screws through and to slide onto pegs molded into the gauge cluster...so a flat piece wouldnt fit right...you should be able to get one at any local JY for a little bit of nothing...
Josh
Josh
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Josh
Josh
exactly, you are correct...that is why i said it is easier...it is actually pretty cool exactly how interchangeable our cars ACTUALLY are....
Josh
Josh
Car: 84, 86
Josh
Josh
I'd probably have better luck with one from a donor than making my own anyways....
Thanks for the info, and special thanks to deadbird for the pics....
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
I still like the grid style speedo.
Where did they get that bucket!! I gotta have one for my front seat!!!
Josh
Josh
Has anyone on here done this, and is is a straightforward swap? I'd probably swap the tach too as I still have a V6 tach in my cluster.
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Interesting... we could probably do that to the 85... in fact I think in that first pic that IS an 85...
Question:
Can you swap the needle from the Firebird speedo to the Camaro speedo? I think it would help in attempting to unify the dash after the conversion.
CarGuyDennis
137
12-06-2016 11:02 PM
Fast355
12-02-2016 06:33 PM
