1986 Iroz shifter ball
Car: 1986 irocz
Transmission: automatic
Hi I just purchased a 1986 iroc with an automatic trans. The shifter ball slides down the shaft and the previous owner had electrical tape on the shaft holding it up. Does anyone know what I would need to fix this problem . Thanks
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
well, dont call it cut and dried that fast. i know on my 86 Z28, the problem actually is not the C-Clip missing, but the part of the plastic shifter that holds it is broken out. so C-Clip or not (hell, mine was still in place) it still slides all the way down the shaft...its freakin annoying, ain't it?
Josh
Josh
sjorgens
10-01-2015 07:54 PM
