Whats that stuff that goes over your head?
Car: 1990 Camaro "RS"
Engine: 355 TPI
Axle/Gears: 3.23 LSD
Hey guys another question for you all. Whats that stuff thats right over your head in the car? Its all orange foam for me, I know theres supposed to be some sort of cloth or something covering it, but is there a name? I"d like to put the cloth stuff up there because that orange foam breaks apart kinda easy and leaves dustings in my hair lol
for upcoming responses
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
Engine: 355 TPI
Anyway that I can buy like a sheet of felt and put that stuff up myself? Is it hard or anything?
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
You can buy the headliner material from any automotive upholestery shop. It comes with the foam attached to it. You need to remove the foam that's stuck on the board right now and glue the new material/foam on.
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
its sooo much easier to getit done. my headliner was done custom in my car for 175$ that was in tweed with a 3d Bowtie in the middle of it. that included new sail panels and new sun visors...
Engine: 355 TPI
I don't think theres any upholstery shop here dealing with autos...... any online retailers? All I see from this hawks third gen parts is t tops headliners and thats it.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
go to any fabric store, I've bought it at Joanne fabric. Ask them for headliner cloth and they'll know what you're talking about. there should be several colors to choose from... it's a felt-like cloth with a 1/8" foam backing. If you look in the technical article section, you should find instructions on how to apply it. My #1 piece of advice is to clean off ALL of the old foam before adhering the new headliner or it'll just fall down again. Also, use the strongest 3M adhesive you can find. I used one called "Super Trim Adhesive" and it's product # 08090. One more piece of advice, you're much better off taking the headliner out of the car to do this than trying to work upside down. Good luck
Engine: 355 TPI
so you mean attaching the headliner to the new foam outside my car? then when im ready, use that 3M stuff to glue it in the bare top?
Engine: 355 TPI
Thanks..... it would seem the foam I have above is in fair shape and should hold up the felt just fine. Now its a matter of taking it out of my car that seems to be the harder part...
509 camaro fan
09-06-2015 10:43 AM
